lost 4 mpg with DP Tuner 80 Econo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_randysford, this thread has received 17 replies and been viewed 3622 times.
post #1 of 18 (permalink) Old 11-24-2007, 06:36 PM Thread Starter
I've got a F5 chip with no start, stock, 40 tow, 60 tow, 80 tow, 80 econo, 120 race, 140 extreme, 140 SMOKE. I've ran 2 tanks so far since the chip install. Each tank i'm down 4 mpgs on the 80 econo and normal everyday driving. Also it seems to have more turbo lag. Say going 45 mph in 6th gear and floor it. It takes like 5 secs to build up to 55 mph. Then once it hits 55 the truck takes off like a rocket. If i have to pass or just build up speed on a hill going 45 i have to down shift. It does that in every setting EXCEPT stock. In the stock setting it has almost no lag it just goes. Also when taking off hard and shifting gears the motor stays revved up between gear shifts. Makes shifting kinda weird. Also, when going say 70 on the interstate and floor it to pass someone then let off the motor stays revved. Then it drops like a second after i let off. Is all of this normal? Think something is wrong with the programming of the chip?
imported_randysford is offline
post #2 of 18 (permalink) Old 11-24-2007, 08:33 PM
strokin now cummin later!
Orangepstroke's Avatar
send a pm to "seeya" and talk to daine or call 828-221-0076 and talk to jody.
i dout anything is wrong with the chip but they will be glad to work with you and see if they can find the problem.:Thumbup:
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #3 of 18 (permalink) Old 11-24-2007, 09:50 PM
plainredtruck's Avatar
Images: 11
They won't be back online or in the office until Monday, but I would give them a ring and send Diane (SeeYa) a PM now for certain.
They'll help you figure out the problem.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 18 (permalink) Old 11-25-2007, 12:27 AM
Mafia Member #93
blk99's Avatar
well I'll tell you that your lag problem is probably that stock exhaust!
I have a buddy that did the same thing. Got the chip before the exhaust and he noticed the same thing!
But the rest of the stuff might be something that Jody accidentaly missed in his programing. I have one little minor thing also where when I come to a stop in the 60 tow setting the idle stays up at about 850 RPM. And it only does it when it is warm but I dont really care. It doesnt bother me.
blk99 is offline
post #5 of 18 (permalink) Old 11-25-2007, 06:54 AM
TDG Mafia Member #73
The 80E tune is made to be easy at low RPM's. That is why it is the Economy tune. If you want more aggressive bottom end, get a Tow tune. I think this was mentioned on the other forum as well.
mattymx is offline
post #6 of 18 (permalink) Old 11-25-2007, 03:33 PM Thread Starter
I've got 3 tow tunes and they all have the same sluggish feelin.
post #7 of 18 (permalink) Old 11-25-2007, 05:09 PM
You are only a few miles away from Swamps. take it over to them and see what they say. johnathan is a great dude.
Swamp's Diesel Performance (615) 793-5573
304-A Sand Hill Road
La Vergne, TN 37086
(About 10 miles south-east of Nashville, TN off of I-24)
mattymx is offline
post #8 of 18 (permalink) Old 11-26-2007, 07:59 PM
Steel's Avatar
my truck had serious lag as well until i got an exhaust, some people wouldn't think that an exhaust would do that much, but it really helps with spool up
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
post #9 of 18 (permalink) Old 11-27-2007, 01:31 AM Thread Starter
Talked to Jody today. He's gonna do some changes and send me another chip out tomorrow.
There's reasons that i went with DP. That is one of them.
post #10 of 18 (permalink) Old 11-29-2007, 05:36 PM
my truck was doing the same thing after i installed my DP chip. when i was ordering, the other guy (not jody...can't remember his name) told me the tow and econo settings are the same except for tranny programming, meaning for anyone with the 6spd they're the same tune.
I have 80 econo (aka 80), and for a while sometimes it would be sluggish as ****, just like you described....the going 45 and taking 10 seconds to hit 55 but then building boost and taking off is EXACTLY what mine was doing. i found out the problem was i had a bad connection at the switch and cable. RIGHT at initial key-on, my switch...instead of doing the little spinny thing and then showing #4 (my position for 80e), the decimal point would keep blinking. if the decimal point was blinking while i started my truck, it would drag *** like you describe. if i jiggled the interface and got a 4 to show up BEFORE starting, it ran/runs like a raped ape. if i started the engine with the decimal blinking and afterwards jiggled the switch to get the program number to show, i would have key off and back on and start the engine to get the power back.
i had to take the switch/cable apart and bend the switch pins in towards each other just a little, and all my problems went away. if you search my username, in my mandatory "all hail the badasness of DPtuner" thread you'll see i love(d) the tunes but i thought the switch and cable ends of the plug were junk and need some kind of latching mechanism. i wrote that post while having issues with the connection. since bending the pins the problems have gone away, but i still dont think i should be having to bend anything around in the first place after what I paid for the product. anyway, that's another discussion
just something to check for. when you key on make sure it very quickly goes to the program number. mine screwed up like 50% of the key on cycles before i bent the pins in.
good luck
Paul
edit: wow, i forgot how touchy-feely this forum was about "bad words"...
2002 Arizona Beige F250 Ext Cab Short Bed. 7.3L 6spd 4x4 140k
2" leveling kit, 285/75 Mastercraft AT2's,Napa BFF, DiPricol Pryo/Boost, DP F5 NS/stock/hi/40/80/120/140agg-lope, Toolbox, Audio goodies, IH shiftknob
muffler delete, CCV reroute, AIH/Foil delete,
paulkeith is offline
