PCM Removal with 6 speed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fire1998, this thread has received 5 replies and been viewed 520 times.
post #1 of 6 (permalink) Old 11-24-2007, 10:38 PM Thread Starter
How the hell do I take the PCM out with a 6 speed. I have removed the middle bolt from the back but still can't pull it out!!!!! The clutch is in the way!!!!
HELP
fire1998 is offline
post #2 of 6 (permalink) Old 11-25-2007, 11:43 AM
dondiesel444's Avatar
you have to remove the whole metal bracket that the computer is bolted to, 2 bolts I think by the clutch pedal, it is a PITA but thats the only way to do it...
NEW2001 Western Star 4964FX double frame tri-axle dump truck, 6NZ CAT Power, 10 speed, Sirius radio.
SOLD1997 Western Star 4964FX double frame tri-axle dump truck, 3406C Cat Power, 8LL, 46K rears on Chalmers, lots of lights, Sirius radio
2001 F-250 7.3 PSD crew cab 4X4 Lariet, DP Tuner ECM, sonnax/tri springs, 3" lift, 305/70R16' BFG's on 16x8 DC-2 wheels, 6637 air filter, straight piped, 04 headlights and turn signals.
dondiesel444 is offline
post #3 of 6 (permalink) Old 11-25-2007, 03:29 PM
The 10mm bolt in the front (which you got). Then the 2 7mm bolts on the inside of the truck. Then press the clutch in with 1 hand and pull the pcm out with the other. That's how i did it.
imported_randysford is offline
post #4 of 6 (permalink) Old 11-25-2007, 05:12 PM
TDG Mafia Member #73
That is the way I did my dads...
mattymx is offline
post #5 of 6 (permalink) Old 11-25-2007, 08:47 PM Thread Starter
Pcm
Got it!!!!!
Thanks
fire1998 is offline
post #6 of 6 (permalink) Old 11-26-2007, 12:39 AM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
hey man if you want it to be easier to remove next time then trim off the dr. side plastic lip on the front of the plastic black bracket that holds the pcm to the firewall. thats what i did and now i can just unbolt the 3 bolts and then pull it towards the pass. side and out it comes. way easier.
just wat i did so i thought i would shed some light.
b/c trust me you will have to take it out again sometime. to reflash it for when you want more power
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
