need advice for dp tuner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by clint1985, this thread has received 2 replies and been viewed 596 times.
post #1 of 3 (permalink) Old 11-25-2007, 05:57 AM Thread Starter
Question need advice for dp tuner
My dads got a 95 7.3L and all he's done to it is change the exahaust to 4 in. Im thinkin bout gettin him a dp tuner prolly the 80 hp econ and 100 performance, and maybe the 140 extreme. Should i worry bout damage to the turbo or the engine since everything else is stock. If you have any other advice for me I would greatly appriciate it. Oh and whats the turbo boost annihilator???
clint1985 is offline
post #2 of 3 (permalink) Old 11-25-2007, 06:13 AM
TDG Mafia Member #73
The max output for a 95 PSD is about 80HP above stock. Any more than that and you are not doing anything. If I were to do it on his truck, I would get 40 TOW, 60 TOW, and 80 ECONO. Other than that if the trans is in good shape it should be just fine. Make sure he gets gauges if he does not already. Bad things can happen due to unwatched EGT's.
Welcome to the Garage!!!!:mafia
mattymx is offline
post #3 of 3 (permalink) Old 11-25-2007, 06:31 AM
moose99psd's Avatar
the boost annialator is a redulator that goes inline with the map sensor witch reads boost pressure to monitor and control the engine. if the map sensor sees more than a predetermined amount of boost it will start to defuel the truck. this only allows the map sensor to see a set amount of boost reguardless of what the turbo is actually pushing out. if you get a DP get this regulator as well. and i agree with matty as to the settings.
moose99psd is offline
