DP 80 ECO VS 80 tow - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skydog, this thread has received 6 replies and been viewed 1844 times.
post #1 of 7 (permalink) Old 11-26-2007, 01:42 AM Thread Starter
DP 80 ECO VS 80 tow
Hey guys love my tune first off. But should my 80Hp Eco be a ton stronger than the 80Hp tow? Mine is if i keep the gas the same and switch the 80Hp Eco is a ton stronger than the tow? Is this right? And my 120 race feels the same as my 80Hp Eco?
Thank you Skydog
2001 Ford X with Racer X Trans and DP tuner
2003 Yamaha Rx1 with Turbo 300hp
2008 Yamaha Rtx Nytro Supercharged !!HAHAHA
25' Motion Cat twin 280 Merc offshores 118 mph
skydog is offline
post #2 of 7 (permalink) Old 11-26-2007, 02:13 AM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
yea my 80e tune is stronger than my 80tow, but not way stronger.
the 120 should be noticeable stronger than your 80e tune.
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #3 of 7 (permalink) Old 11-26-2007, 09:40 AM
plainredtruck's Avatar
Images: 11
Probably just differing power at differing RPMs. Only way to find out it the E is stronger than the T is to put it on a dyno or run it down a track.
Or ask Jody.
Your 120 could be the result of an HPOP that isn't functioning well at higher RPMs.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 7 (permalink) Old 11-28-2007, 04:44 AM
My 120 is much stronger than the 80 econ tune. I can really tell a difference when I switch from 80 to 120. However, with my stock injectors, turbo, and HPOP, the 120 race is stronger than the 140 aggressive. But....the 140 blows a lot more smoke.
imported_ryan is offline
post #5 of 7 (permalink) Old 11-29-2007, 06:10 PM
first, you're not really supposed to be switching programs while under power, or while moving at all for that matter. but do what you want, i'm never on any roads in IL.
second... when i ordered my chip, jody's other employee guy (can't remember his name) told me that since i had the 6spd, the 80e and 80t were the same program since they differed only in tranny tuning. however, from what i've read lately, it seems that maybe tow has more power at lower RPM. If this is the case, i wish i had gotten the 80 "tow" instead of 80 "econo"....but maybe 80 "econo" works better for MPG and daily driving. maybe diane can chime in?
Paul
paulkeith is offline
post #6 of 7 (permalink) Old 11-29-2007, 11:15 PM
When I asked Jody about switching on the fly he told me that he had guys that switched his chips two or three times just during one pull (tractor pulls). Switching while under power and moving is fully condoned by Jody.
80tow and 80econo are different. On their website it has a specific weight range the 80tow is recomended for and the 80econo is recomended for driving around empty and max MPG.
FireHunter is offline
post #7 of 7 (permalink) Old 11-30-2007, 11:38 AM
I also understood that you are not supposed to switch when under power when I bought my F5. My econo tune is a good one and with the few other mods that I have done, if I can tolerate to drive at a reasonable speed on the interstate I have gotten upwards of 20+ mpg not by my fuel guage but by doing the math so I am impressed
2000 F250 Crew Cab, Short Bed, Oxford White, 305x70x16 BFG A/T K/O, 16x10 Alum. Wheels, XM and other stereo goodies, Autometer Ultralite Guages (TRANS, PYRO, BOOST) 3.73's, Dp-Tuner F5 w/ 60tow, 80tow, 80econo, 100, 120, 140 :Thumbup: , AFE Stage II, 4" SS Sraight Pipe, B & W Turnover and Tow n Stow receiver hitch, 08' Tailgate (thanx to Blowin' Smoke) rhino-liner, 05' Grille, newer drink holder, Kobalt full width chest, boost fooler
SOLD 07/08
1989 Dodge W250 Regular Cab (purchased from original owner 10/31/09)
AT, A/C
120,00 miles
needs some goodies
HIGH MILEAGE ELITE is offline
