New Guy Needs Help........ - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by knzj, this thread has received 8 replies and been viewed 696 times.
post #1 of 9 (permalink) Old 12-22-2007, 02:59 AM Thread Starter
My first time so please bear with me.....:shrug:
Live in TX, 2000 Lariat PSD, ~85k, Ext-Cab, 2WD, LWB
Mainly daily commute 25-30miles, but 4-5x/yr. I haul cattle w/28ft gooseneck 50-100 miles.
Desiring best fuel mileage but still need performance for cattle hauls. Don't need a race truck, just reliability.
Was thinking:
4-5" turbo-back SS exhaust (Magna-Flow?,Is SS worth it?)
K&N Series 75 intake?
DP Tuner w/stock, 80 ECON, and 80 Tow settings?
This is my first day on the forum and I have already learned a lot from ya'll.
Any suggestions would be greatly appreciated.
Thanks in advance.
knzj is offline
post #2 of 9 (permalink) Old 12-22-2007, 03:23 AM
TDG Single Club Member#14
big_rooster's Avatar
Send a message via MSN to big_rooster
Where you at in texas? Dfuser in georgetown can hook you up with whatever you need. Welcome to the forums.
2003 F-250 6.0 liter crew cab lariat 4x4 short bed, S&B intake, MBRP 4" turbo back straight piped jones, SCT livewire, : 2 jl audio 12W3V3's with jl audio 500/1, autometer sport comp gauges, 6.5 inch pro comp lift, 37x13.5 Super Swamper M16's
http://s192.photobucket.com/albums/z319/big_rooster69/
big_rooster is offline
post #3 of 9 (permalink) Old 12-22-2007, 03:49 AM Thread Starter
Great to be here!! I am about 40-50 miles North of Georgetown in Lorena, just south of Waco. Thanks for the tip I will definitely look him up!
knzj is offline
post #4 of 9 (permalink) Old 12-22-2007, 04:53 PM
Was thinking:
Thanks in advance.
Go with a 4" turbo-back exhaust. Pick any name brand manufacturer you find. Almost all are good but try and use one of the site vendors for the best support.
A cold air larger intake helps a bunch but I warn you, most 7.3's will get turbo surge with the larger intake. You will find lot's of opinions on turbo surge as to whether it is harmful or not but, I and many believe it is. Then you will need to buy an ATS housing (or a larger turbo) to eliminate surge. So that is another 450 bucks.
Then go with a DP tuner chip. I like the 80 econo for my daily commuting and I'll let others chime in on what tow setting you should get, as I do not tow regularly.
BTW I increased my mileage by 2mgp on my commution in the 80 econo setting.
Your last worry is, once you have done this stuff, you will find your truck has more power than you imagined and you can go much further. You could get the "modding disease" which won't hurt you but, will make a dent in your pocketbook.
D-Man is offline
post #5 of 9 (permalink) Old 12-22-2007, 05:02 PM
Paul Ray's Avatar
i did the 4" turbo back on my 7.3 with the volant cold air induct and yes it is true... the surge is awful.
Paul Ray is offline
post #6 of 9 (permalink) Old 12-23-2007, 02:11 AM Thread Starter
Thanks for the heads up.......I think I'm already feeling the symptoms of "modding" disease!!
I will definitely check with ATS and the turbo surge issue.
Some of the exhaust packages I am looking at have separate packages for "tuner" setups. Does this make a huge difference since the tuner purchase may be a while after the exhaust and intake purchase?
knzj is offline
post #7 of 9 (permalink) Old 12-23-2007, 08:52 PM Thread Starter
I checked out the housing at the ATS site. These guys look like true professionals! Is this housing something I can do?
knzj is offline
post #8 of 9 (permalink) Old 12-23-2007, 11:24 PM
4" turbo back will help. I opted not to spend the extra $$ for SS and it's been fine.
Almost any intake other than stock or K&N will be good. I prefer the Ford AIS but you probably have already read about Tymar's, AFE's, Volant's, etc...
Sounds good on the DP Tuner except I would opt for the 60tow instead of the 80tow. Which leads me to the standard recomendations of GAUGES. The 80tow can still get things pretty hot - especially in your part of the country and hauling that much weight.
Deal with surge if and when you get it. The ATS housing is a great option. I encourage you to read through as many threads as you can and you will find more than a few folks that have a very different opinion about ATS being "true professionals".
$.02
FireHunter is offline
post #9 of 9 (permalink) Old 12-24-2007, 02:31 PM Thread Starter
$.02
Exactly the information I needed FH, thanks!! You anticipated my other questions about gauges etc. It appears that most everyone is a fan of DPtuner. I look forward to giving them a call.
It looks like I will probably do the exhaust and intake first, deal with turbo surge if needed, then maybe look into a tuner. Either way, it looks like I came to the right place to save a bunch of time in research and $$$.
Thanks guys!!
knzj is offline
