hp output on dp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokeone, this thread has received 10 replies and been viewed 1212 times.
post #1 of 11 (permalink) Old 01-20-2008, 11:19 PM Thread Starter
Talking hp output on dp
How many horsies do ya'll think a 99 will put out with a 120 tune from Dp.With cold air and open exaust????has anyone ever done a dyno with this basic setup?
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
post #2 of 11 (permalink) Old 01-21-2008, 05:40 PM
CSIPSD's Avatar
280-310... depending on if your a early 99 or a late.
CSIPSD is offline
post #3 of 11 (permalink) Old 02-05-2008, 06:11 AM
midwestoffroad's Avatar
and if oil pump can keep up.
midwestoffroad is offline
post #4 of 11 (permalink) Old 02-08-2008, 12:56 AM
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
read my sig. those dyno numbers are before the ATS housing, I'm not sure what the differances are between a 99 and my 02 are tho
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #5 of 11 (permalink) Old 02-08-2008, 06:36 AM
CSIPSD's Avatar
That would be a VERY GENERIOUS Dyno...
CSIPSD is offline
post #6 of 11 (permalink) Old 02-08-2008, 01:05 PM
4cstr
With my early 99...with just a DP tuner chip, intake, exhaust the best I could do was 280 something to the rears...my hpop was running out of oil.
After big oil...my numbers are in my sig.
post #7 of 11 (permalink) Old 02-08-2008, 02:52 PM
CSIPSD's Avatar
You my friend... Need some injectors...:nitrous: :smoke :
CSIPSD is offline
post #8 of 11 (permalink) Old 02-08-2008, 02:59 PM
plainredtruck's Avatar
Images: 11
283 was what my early '99 with intake, exhaust and DP's tunes did on Dunbar's. I wouldn't call it "generous".
32x is standard for later models with similar mods on Dunbar's Dyno from what I've seen.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #9 of 11 (permalink) Old 02-08-2008, 06:41 PM
4cstr
When the time comes. Right now my current injectors are pushing fuel just fine. Still debating on singles versus splits.
post #10 of 11 (permalink) Old 02-11-2008, 01:50 AM Thread Starter
I have a late 99.I purchased the truck around august and am still learning what has been done to it.Kinda like the garett powermax turbo that the previous owner installed on it.I kinda got suspicious when my friends 2000 with a dp tuner and other basic mods ate some of my smoke.We got under hood and started investigating it.Turbo was still a little shiny.so we started runin #son it and waallaa.I like it when you find surprises under the hood!!and P.M.S. is badd
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
