boost gauge buried on Dp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokeone, this thread has received 19 replies and been viewed 1236 times.
post #1 of 20 (permalink) Old 01-26-2008, 01:58 AM Thread Starter
:smoke I recently added a dp tuner to my truck. I can bury my 35# boost gauge in a matter of seconds. I thought the gauge was broken so I tried my friends gauge in place of mine same effect. I have only owned this truck for about 7months now.I was thinking maybe previous owner has some other upgrades done to truck.But I have no clue I wouldnt know what to look for to be honest since the truck does not have head studs should I Install a pop off or something of the sort to limit he boost?and what is a safe level for these trucks. btw it does this in the 80e and the 120r modes I am almost considering getting studs cause I love the power level truck will go sideways when it shifts gears with foot to floor.:smoke
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
post #2 of 20 (permalink) Old 01-26-2008, 04:52 AM
Mafia Member #93
blk99's Avatar
wow that thing has got to have a big ***** turbo or some bigger injectors!!!!
headstuds are really only needed after about 40# of boost but it still would not be a bad idea!
EDIT: maybe to see if it has a big turbo, you should take some pics of it and see if we can tell....
Oh and how much smoke?? any at all????
blk99 is offline
post #3 of 20 (permalink) Old 01-26-2008, 04:56 AM
Supporting Vendor
SeeYa's Avatar
Images: 1
80E you should see 28-32 psi
120r you should see 35-40 psi
SeeYa is offline
post #4 of 20 (permalink) Old 01-26-2008, 04:35 PM Thread Starter
Thanks I was just wondering. truck is doing great now thanks to you and Jody. I still have yet to get the pics and write up out to you will do soon.
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
post #5 of 20 (permalink) Old 01-26-2008, 04:39 PM Thread Starter
It will smoke some but not alot.I,ll try to get some pics of smoke and under hood.I had heard 40 was about the limit but was not sure.I think that I will purchase a 60# boost gauge.that way I will see what it is doing
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
post #6 of 20 (permalink) Old 01-27-2008, 12:11 AM
strokin now cummin later!
Orangepstroke's Avatar
35-40npsi on intake, dp chip, and exhaust?
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #7 of 20 (permalink) Old 01-27-2008, 01:16 AM
Supporting Vendor
SeeYa's Avatar
Images: 1
Oops, you can see when I posted that.
I apologize to the op. :sofa
80E should see 28-30 psi
120R should see 30-32 psi.
Definatley need bigger injectors to make higher boost numbers then that.
SeeYa is offline
post #8 of 20 (permalink) Old 01-27-2008, 02:47 AM Thread Starter
So maybe I might have injectors or something I will have to tinker on it and see.I was looking at my turbo and comparing to my friends 2000 mine has same name on it but diff #s.Mine is much mo shiny then his like it could be newer or just beter taken care of.he has a ts chip and envies my truck now. he is saving for a dp tuner.
OP what is the tans lock up for does it help in any way? Also I have a potentiometer that is wired into my idm ohm value of 1k to 10 k it is on a toggle switch have never used it in conjunction with chip what do you think that would do.Read your sig obviously just curious of your thoughts.
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
post #9 of 20 (permalink) Old 01-27-2008, 03:37 PM
maybe its an early 99 thing? I was told at the .org that I couldn't set off my cel for overboost with a stock truck, but whaddya know at 2400 rpms I can run 21-22 lbs. and It'll still climb
Luke
Binder Man is offline
post #10 of 20 (permalink) Old 01-31-2008, 07:12 PM
I can barely get 25 psi at 80mph on the 120 setting, what would cause the difference?
2001 F-250 7.3L Ext. Cab, SB 4X4, MBRP 4in, DIY intake, autometer pillar gauges, DP F5 tuner (40,80 and 120), ride-rite air springs, 08 Diff. cover.
1977 F-250 5.9L Cummins Nv4500 Dana 80
4wydnr is offline
