mpg with dp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by camojeeper, this thread has received 13 replies and been viewed 1122 times.
post #1 of 14 (permalink) Old 02-11-2008, 07:48 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
mpg with dp
i know another ? about dp!! i do a lot of freeway flat long mileage down I-5 at about 2200 rpm does any one have a dp tune for mpg at this rpm or should i just get the 80E? I am avg 13.6 every 100gals trying to get 16 or better.
I also pull heavy trailers i dont have a problem(egt's) pullin em now with my edge evo set @100hp so what tow tune if any should i have trailer weight from 5000 to 17000. and last i want a hp tune but not sure which one look at my sig to see my mods and tell me what you think. I want all of the power i can get. not planin on big oil maybe stage 1s down the road, no drugs or LP. thank you for your time steve I want the dp f5 just not to sure on what to order i think im gonna do 3 pos 80 tow 80 E 120r/140 i think
oh yea whats the difference between 140ex and 140 agressive?
thanks everyone steve
STEVE TDG MAFIA#106
camojeeper is offline
post #2 of 14 (permalink) Old 02-12-2008, 01:57 PM
At 2200 RPM's down the highway, you've shot yourself in the foot when it comes to mileage. Best bet is to call and talk to Jody and see if he has any tricks up his sleeve for mileage tuning at those RPM's. Unless you slow down, I don't think you'll see more than 16 mpg.
Pocket is offline
post #3 of 14 (permalink) Old 02-12-2008, 04:32 PM
beware the dark side
i have the dp tuner and on the 80 econo tune i got 20 miles to the gallon running a 500 mile round trip. it was in the middle of the night and i had the cruise set both ways at 75 mph. not sure what the rpm's was but i have 3.73 rear so should have been around 2000 i believe. i have not had better mileage with any other chip. I also use the 80 hp tow for pulling the fifth wheel camper and have not seen any egt issues yet but have only seen a few good grades with it. the difference between the 140 aggressive and 140 ex is the amount of fuel the motor gets on the bottom end. The aggressive will smoke more from the start at a light but the 140 ex doesn't smoke as much. contact jody at dp tuner and he will be able to help alot more. I spoke to him and he is a good guy to deal with.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #4 of 14 (permalink) Old 02-12-2008, 07:33 PM
You should talk with DP but I think you better get a lower hp tow tune also. Unless you care to watch the egt gauge while you have the 17k trailer hooked to it.
Eric
Dually Club Member #53
racehauler is offline
post #5 of 14 (permalink) Old 02-12-2008, 09:13 PM
midwestoffroad's Avatar
what speed are you at @2200 for me it is 80 you may want to just try slowing down a 100 rpm at a crack and see what happens.. i have the 80t,80e and 120 reprogramed EVO ir is great.. littel to no smoke and pulls like mad. best i seen on my overhear was 18.7 which was close to what was hand calculated ..80t was almost 15
midwestoffroad is offline
post #6 of 14 (permalink) Old 02-13-2008, 12:52 AM
Diesel Pro
Macktruckdriver's Avatar
Driving at anything over 2000 RPM is going to kill fuel mileage. I never run over 2000 unless I have a good reason to hall A** for a few mile like PO-PO's or running away from my buddies duracrap.
Macktruckdriver is offline
post #7 of 14 (permalink) Old 02-13-2008, 04:30 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
thanks guys for your opinions slowin down is really not an option as i drive about 200mi each way to work strait and flat/boring and long if i slow down to 70 or 75 i just seems like forever. i thought about a gear change to get down to 2000 or even 1800 but thats not always a cure. @2200 im doin 80 makin about 8-9lbs and about 550 on the exhaust. i figure my miles on every fill up usully bettween 100-140 gal fill up thats every two weeks or so. so its hard to see a change of 100 or 200 rpm.i will just have to call jody i guess thanks for you time steve
STEVE TDG MAFIA#106
post #8 of 14 (permalink) Old 02-13-2008, 10:29 PM
find someone with some larger tires 285 295 that is oif you are running 265's yet.. it would be a quick way to drop some rpms.
post #9 of 14 (permalink) Old 02-13-2008, 11:27 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
all ready runnin 285's
STEVE TDG MAFIA#106
post #10 of 14 (permalink) Old 02-14-2008, 06:07 AM
How are you doing that kind of mileage? I have a dp, intake and exhaust and I'm only getting 10.5 in town or on the highway. I've had the dealer check everything. What are you doing different, I wonder?
Superball is offline
