pcm ?s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by camojeeper, this thread has received 9 replies and been viewed 560 times.
post #1 of 10 (permalink) Old 02-11-2008, 07:51 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
pcm ?s
how can i find out what computer i have the door stickeer is gone and there isnt one on the pcm either? is there any where else to look?
thanks steve
STEVE TDG MAFIA#106
camojeeper is offline
post #2 of 10 (permalink) Old 02-11-2008, 10:14 PM
GOS
GOS's Avatar
Calibration Code
If you pull the pcm you should be able to see the code. PCM's have a little sticker on the black plastic plug with the code. Also if you totally remove the computer there is a bar code sticker on the big plug end that also has the code.
Contact 1-800-620-4467
Fax 1-406-222-4926
[email protected]
GOS is offline
post #3 of 10 (permalink) Old 02-12-2008, 12:47 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
:shrug: SO HOW DO I PULL IT? proper procedure? for removel do i have to get the bolt out of the harness under hood or can it be removed from in the cab? trying to find out whitch one i have so i can get a dp tuner for my truck mfg date 6/99
STEVE TDG MAFIA#106
post #4 of 10 (permalink) Old 02-12-2008, 01:17 AM
I beleive that there is a video on here that shows how to install a dp tuner chip in a pcm it will also show you how to remove the pcm I think.worth a shot any way.(in the stickys)
99F-250 cold air
Dp40t,80t,80e,120r
gt38r 4" pipes
smokeone is offline
post #5 of 10 (permalink) Old 02-12-2008, 01:33 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
didnt even think of that thanks
STEVE TDG MAFIA#106
post #6 of 10 (permalink) Old 02-19-2008, 05:36 PM
4cstr
You will need a 10mm socket and a 7mm socket.
1. You will need to go undo the 10mm bolt that holds the harness to the PCM into the engine bay. Its located directly under the master cylinder. Using a 1/4" drive socket is the best. It takes a bit of time...but its doable.
2. Once you have that bolt undone...there are 2 7mm bolts that hold the PCM holder inside the truck...by the emergency brake pedal. Loosen up those bolts. Once removed...you should be able to carefully pry up and out the pcm. It will then come out of the plastic case. You should then be able to see a PCM code on the part that plugs into the harness in the engine bay.
Hope this helps.
post #7 of 10 (permalink) Old 02-19-2008, 07:39 PM
TDG Mafia Member #73
Just use a mirror and angle it down to where the PCM connects to the plug in the engine bay. A small dentist mirror works best. You will see a white sticker with the PCM code on it.
mattymx is offline
post #8 of 10 (permalink) Old 02-20-2008, 04:20 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
thank you every one i ordered my dp today hope jody gets back from ca soon i really want it bad
STEVE TDG MAFIA#106
post #9 of 10 (permalink) Old 02-20-2008, 04:27 AM
Come to Bakersfield this weekend. That is where he will be will all of his tuning goodies.
mattymx is offline
post #10 of 10 (permalink) Old 02-20-2008, 11:02 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
ya i talked to him monday before he left. new baby at home ,no time, sure wish i could have fun with out me
steve
STEVE TDG MAFIA#106
