how hot can i run the pyro - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ethanwko, this thread has received 11 replies and been viewed 1306 times.
post #1 of 12 (permalink) Old 02-15-2008, 10:30 PM Thread Starter
i have the pyro probe installed in the exhaust manifold and was wondering how hot i can run it any info thanks
2000 f-350 7.3
ethanwko is offline
post #2 of 12 (permalink) Old 02-15-2008, 10:38 PM
In short bursts, you can peg the gauge. Guys do it all the time in sled pulls and drag strip runs. However daily driving, towing up say a mountain grade, don't let it exceed 1250 degrees for any longer length of time.
Pocket is offline
post #3 of 12 (permalink) Old 02-15-2008, 10:47 PM
MAFIA MEMBER 106
camojeeper's Avatar
i was told 1350* was the danger zone and not to let it pass there
STEVE TDG MAFIA#106
camojeeper is offline
post #4 of 12 (permalink) Old 02-18-2008, 09:52 PM
obviously the lower the better but like earlier mentioned you can run high in shorter bursts, its your truck none of us have to pay the repair bill run at your own discretion
2000 F250 Crew Cab, Short Bed, Oxford White, 305x70x16 BFG A/T K/O, 16x10 Alum. Wheels, XM and other stereo goodies, Autometer Ultralite Guages (TRANS, PYRO, BOOST) 3.73's, Dp-Tuner F5 w/ 60tow, 80tow, 80econo, 100, 120, 140 :Thumbup: , AFE Stage II, 4" SS Sraight Pipe, B & W Turnover and Tow n Stow receiver hitch, 08' Tailgate (thanx to Blowin' Smoke) rhino-liner, 05' Grille, newer drink holder, Kobalt full width chest, boost fooler
SOLD 07/08
1989 Dodge W250 Regular Cab (purchased from original owner 10/31/09)
AT, A/C
120,00 miles
needs some goodies
HIGH MILEAGE ELITE is offline
post #5 of 12 (permalink) Old 02-18-2008, 11:04 PM
CSIPSD's Avatar
You DO NOT want to run that high for sustained periods of time.
IH tells us 1250 all day and no issues. You can run over that for 10-30 seconds depending on were you were before. Its about heat soak. If the pistons were at 1200 before you went over 1250 then it will take seconds to reach a danger level, but if you were cruising along at 600-700 then you can go for much longer before they reach that danger level.
CSIPSD is offline
post #6 of 12 (permalink) Old 02-19-2008, 12:22 AM
*^%$#@&am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;!! !!!
AUSSIEDAVE's Avatar
1250 all day no issues?
does that include hauling heavy up hills?
FORD AUSTRALIA 2003 F350 DRW FLATBED
SUPERDUTY XL SUPERCAB 4X4 7.3 PSD 6 SPEED MANUAL GARRETT GT38R TURBO BANKS TECHNICOOLER 4 INCH DOWN PIPE AND MITRED STACKS DP TUNER GEARVENDORS OVERDRIVE ALCOA HOTSHOTS CUSTOM INTAKE
FORD AUSTRALIA 2007 RANGER
XLT CREWCAB 4X4 DP
INLINE 4 CRD TURBO DIESEL 3.0L 5 SPEED MANUAL
33MPG DP CHIP
SOLD FORD AUSTRALIA 2002 F250 FLATBED
SUPERDUTY XL SUPERCAB 4X4 I6 4.2L MWM TURBO DIESEL ZF5 SPEED 23MPG 425FT/LBS @1500RPM
http://www.youtube.com/watch?v=7FrJu...e=channel_page
www.myspace.com/skyzakyte
AUSSIEDAVE is offline
post #7 of 12 (permalink) Old 02-19-2008, 12:31 AM
CSIPSD's Avatar
Yes. This is what IH has said in the past... I use 1200 for my sustained limit most of the time, just for a bit of a safety and gauge error cushion...
CSIPSD is offline
post #8 of 12 (permalink) Old 02-19-2008, 04:46 AM
MAFIA MEMBER 106
camojeeper's Avatar
remember these temps are pre turbo. if you egt probe is post(after turbo in the down pipe) you should not run above1000*
STEVE TDG MAFIA#106
post #9 of 12 (permalink) Old 02-19-2008, 05:29 AM
Shouldn't even run a post turbo pyro anyway. It's a waste of a gauge.
Pocket is offline
post #10 of 12 (permalink) Old 02-19-2008, 08:16 AM
Mafia Member #93
blk99's Avatar
you mean you actually have "gauge error" with those Performax's????
WOW!! woulda never thought that could happen!!
:roflmao: :roflmao:
blk99 is offline
