Ford and DP Tuner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RVHAULER, this thread has received 10 replies and been viewed 847 times.
post #1 of 11 (permalink) Old 03-07-2008, 12:38 PM Thread Starter
Question Ford and DP Tuner
Took the truck in this morning to have the CPS replaced due to the recall and have a question about DP Tuner and Ford diagnostics. Planning on a DP Tuner install later this month or early April. Not being much of a motorhead, just enough to be dangerous, my question is: With a DP Tuner installed and if I need to take the truck to Ford or another repair shop and they run a diagnostic check what if anything does that do to the DP Tuner or do I just need to place it back in the stock setting before it goes to the shop?
RVHAULER is offline
post #2 of 11 (permalink) Old 03-07-2008, 01:31 PM
TDG SinglesClub Member#90
For that question, I would call Jody and talk to him.
But you can allways take the chip out before you take it into the shop.
1996 Ford F350, 7.3 PSD, crew cab, 8ft(Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Nitto Terra Grapplers, 222,000 miles, DP-Tuner Chip NS 1200 high idle stock 60Tow 80econo 120Race, 3x4" down pipe, 4" exhaust straight piped with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #3 of 11 (permalink) Old 03-07-2008, 01:37 PM
fordt
You really need to take the chip out, it's not a big deal and take's 5 minutes if you take a break half way through
post #4 of 11 (permalink) Old 03-07-2008, 01:42 PM
Dually Club #3
jdydiesel's Avatar
You will have to take the chip out. If you don't it will cause issues with the Ford diagnostic tools.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #5 of 11 (permalink) Old 03-07-2008, 04:37 PM Thread Starter
Thanks guys. I wondered about taking it out first. When I order the turner I'll ask Jody about it too and I'll post his answer.
RVHAULER is offline
post #6 of 11 (permalink) Old 03-07-2008, 04:53 PM
MAFIA MEMBER 106
camojeeper's Avatar
my truck doesn't go to ford problem solved they just dont kno chit about our engines
STEVE TDG MAFIA#106
camojeeper is offline
post #7 of 11 (permalink) Old 03-07-2008, 06:33 PM
TDG Singles Club #112
cummins_cowboy's Avatar
What Did I DO?
Send a message via Yahoo to cummins_cowboy
:iagree
Sam :grd
Early 99 F-350 4wd SC LB Lariat 7.3/ZF-6
S&B Air Box,4in dp, 5 inch straight pipe
DP F5 with hi idle, 60 tow, 80 econo, and 120 race
SS HPX line, ITP Overboost Annihilator, CCV mod
1995 Pontiac Formula Firebird LT1/6spd
1977 Chevrolet K-20 4spd
1973 Peterbilt 359 Big Cam/ 13spd
1989 Peterbilt 379 Long Hood B model/13spd 22' Mid-America Combo Box
1985 Peterbilt 359 Big Cam / 13spd
cummins_cowboy is offline
post #8 of 11 (permalink) Old 03-07-2008, 11:27 PM
AKCCF350's Avatar
Even if you take the chip out, doesn't the computer still log a code that tells them a chip was installed? This is what I was told and I am not sure if it's true.
97 F350 CC LB 4x4 7.3L
Tymar Intake, DP Tuner F-5, Straight Exhaust, 37" Cooper STT II,
SuperDuty Quad-Pod
Parts sitting waiting to install: Moonvisor, 1.0 Exh. Housing, White Faced Dash Gauges, Air Horns (still need compressor)
All Mods on hold as of 2-1-09. Building a rig for my dad.......
AKCCF350 is offline
post #9 of 11 (permalink) Old 03-08-2008, 02:55 AM
CSIPSD's Avatar
I have never pulled the chip. No issues. But my truck has only been in the shop once, everything else I do my self or it goes to a "diesel" shop.
CSIPSD is offline
post #10 of 11 (permalink) Old 03-08-2008, 03:50 AM
4cstr
It might...not sure. But...the tell tale sign that a chip was installed is that you need to clean the computer contacts on the PCM off before installing the chip. Ford sees that "epoxy" stuff missing...and alarms go off about a chip...whether or not there is one in at the time.
As for the dealer...my truck doesn't go near the place. With the cps recall...I called the service manager and he agreed that it would be better to just give me the cps and let me install it than bring the truck in.
