dp tuner and dfuser 18 k module - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by camojeeper, this thread has received 7 replies and been viewed 930 times.
post #1 of 8 (permalink) Old 03-09-2008, 04:13 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
so now i got a dp tuner f-5 well u know and i was wondering how those of you that have an 18k and dp set your 18k dial all the way left or to the right? i know that the far right is max icp psi and way left is lower icp psi so where do you run yours at???
and #2 what do you set it at when doing the 80 e tune for mpg?????????????
thanks steve
STEVE TDG MAFIA#106
camojeeper is offline
post #2 of 8 (permalink) Old 03-09-2008, 04:16 AM
AKCCF350's Avatar
I am not too sure, I thought the Chip would take care of that for you. I guess that's what other have said before. :shrug:
97 F350 CC LB 4x4 7.3L
Tymar Intake, DP Tuner F-5, Straight Exhaust, 37" Cooper STT II,
SuperDuty Quad-Pod
Parts sitting waiting to install: Moonvisor, 1.0 Exh. Housing, White Faced Dash Gauges, Air Horns (still need compressor)
All Mods on hold as of 2-1-09. Building a rig for my dad.......
AKCCF350 is offline
post #3 of 8 (permalink) Old 03-09-2008, 05:56 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
the chip does however the 18 k tweeks the ips when i had my edge evo i talked with bill @ dfuser and he told me that he ranthe same set up and to the right was drivablity and to the left was for top end just woundering what every one else is doing?
STEVE TDG MAFIA#106
post #4 of 8 (permalink) Old 03-09-2008, 06:59 AM
Jody at DP-Tuner already programs some pretty high ICP tables in his tunes. Adding the 18K mod on top of that will only call for waaaaaaay more oil than your stock HPOP can keep up with. Jody's fueling/ICP tables are pretty good as they are now, and you'll be lucky if your HPOP can even keep up with his higher HP tunes as they are now.
Pocket is offline
post #5 of 8 (permalink) Old 03-09-2008, 08:27 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
thats what i was wounderin i allreay had the 18k on the truck when i got my dp so would you take it off?
STEVE TDG MAFIA#106
post #6 of 8 (permalink) Old 03-09-2008, 02:21 PM
I wouldn't run an 18K mod with DP-Tuner. It's only going to set the P1211 code more often than if you ran without it.
Pocket is offline
post #7 of 8 (permalink) Old 03-09-2008, 03:37 PM
TDG Mafia #76
John_DeereGreen's Avatar
Camo, if you don't want that 18K box, I'll take it off your hands.
Like some others said, Jody's tunes will probably come close to maxing out your HPOP's capacity as it is...
Jarrett
04.5 qcsb commonrail
Smarty TnT
John_DeereGreen is offline
post #8 of 8 (permalink) Old 03-10-2008, 09:20 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
ok heres the update i talked with jody today and he said to take it off. he also said that i could play with it on flat groun and maybe pick up some mpg but olny on flat ground so i will take it off. thank you to all for your time
steve
STEVE TDG MAFIA#106
