Option to ATS housing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fire1998, this thread has received 6 replies and been viewed 774 times.
post #1 of 7 (permalink) Old 03-11-2008, 11:28 PM Thread Starter
Has anyone tried this housing for the 7.3 turbo. After I DP'd my truck I am suffering from turbo surging.
Thanks
http://www.beansdieselperformance.com/99-03turbo.htm
fire1998 is offline
post #2 of 7 (permalink) Old 03-12-2008, 02:18 AM
midwestoffroad's Avatar
it will cure it completely ,, I have it and the wicked wheel the WW alone didnt help at all.
midwestoffroad is offline
post #3 of 7 (permalink) Old 03-12-2008, 02:19 AM
You need to fill out your sig so we can better help/diagnose your problems.
cumminsdieselfreak is offline
post #4 of 7 (permalink) Old 03-12-2008, 10:16 PM
Yes, the ATS housing is a great cure for surging.
Slated4Greatness is offline
post #5 of 7 (permalink) Old 03-17-2008, 02:55 AM
I went with the 1.0 exhaust housing. No surge and cheaper.
02 F250 CC, 4X4,SB. DP Tunes stk, 80econ,120. NAPA 6637 air element. Summit 4" turboback. GDS hi-flo outlet. 1.0 turbine housing. HX cross-over. Modded pedestal. CCV mod. Fuel rails connected. AIH delete, pre-pump.
Tyrod is offline
post #6 of 7 (permalink) Old 03-17-2008, 05:47 AM
i did the 1.0 exhaust housing when i did the wicked wheel i mentioned above.. still surged like crazy...on dp 80 econ setting
post #7 of 7 (permalink) Old 03-17-2008, 07:20 AM
Personally I wouldn't waste my money on the housing in the link. If you want a 1.0 housing get one of the ones that have been available for a long time WITH a wastegate! Your drive pressure will stay lower and your boost will be more controllable. The spool up will be the same because it's still a 1.0 housing. This housing is good for engines that run at a single rpm like a generator and has absolutly no advantage over a 1.0 wastegated housing but has the dissadvantage of higher drive pressures at higher rpm/throttle settings because it doesn't have a wastegate to dump the excess.
Are you referring to the compressor or turbine housing from ATS? The pic is of a turbine housing.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
