DP? when? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ford7.3sd, this thread has received 6 replies and been viewed 494 times.
post #1 of 7 (permalink) Old 03-16-2008, 12:14 AM Thread Starter
ford7.3sd's Avatar
DP? when?
i want to get a DP tuner but i want to know if i should wate to get an exaust or just go ahead and buy a DP?
TDG Singles club member # 101
2001 Ford ext. cab, long bed, SRW, auto, 4x4, 7.3 L,trans lock up mod,Deoblo sport predator tuner,AEM CAI 4" superlift
37 inch ss-m16s, auto meter gauges (boost,piro,trans),05 headlights, and clear cab lights. and a weatherguard cross box
ford7.3sd is offline
post #2 of 7 (permalink) Old 03-16-2008, 12:53 AM
Found On Russ' Drive
Russ's Avatar
General time line... 1 exhaust....2 gauges... 3 tuners.
Duct tape... turning No No No into mmmmmm mmmmmmm mmmmmmm
Stormtrooper::1997 F-350 CC SRW PSD XLT 4X4: 332 hp 660 tq. made with Baby Swamps, Wildman 4 pos chip, 120V IDM, CCV mod, shimmed FPR, BTS E4OD, Baldwin air filter,triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner mod, diamond cut headlights,Recon LED tailgate lights Hadley air horns,
Russ is offline
post #3 of 7 (permalink) Old 03-16-2008, 01:12 AM Thread Starter
ford7.3sd's Avatar
dang i want backwards.
post #4 of 7 (permalink) Old 03-16-2008, 03:02 AM
TDG Mafia #95
bluovaltruk01's Avatar
You can get the DP before the exhaust..but you won't notice the full potential with it being stock, plus you will get higher EGTs with stock pipes.
bluovaltruk01 is offline
post #5 of 7 (permalink) Old 03-16-2008, 03:49 AM Thread Starter
ford7.3sd's Avatar
yea i knew i will get higher EGTs but i can keep an eye on them with my gauge. i think i will do both at the same time,i want to get rid of my tuner i have now.
post #6 of 7 (permalink) Old 03-16-2008, 04:54 AM
midwestoffroad's Avatar
the tuners usually take a exhaust mod into consideration in ther programming. you should do 1.exhaust and 2. air intake then 3.gauges and 4. tuner.
midwestoffroad is offline
post #7 of 7 (permalink) Old 03-16-2008, 05:21 AM
If you have gauges, heck, go for it. you only really need to worry about EGT's when towing, daily driving or racing you dont even need to bother looking at the gauge. Unless you are sustaining the temps for over a minute, it doesnt get the pistons hot enough to do damage.
MrStroker is offline
