dp f5 on OBS... How Long? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97UTPSD, this thread has received 8 replies and been viewed 1053 times.
post #1 of 9 (permalink) Old 03-21-2008, 02:34 AM Thread Starter
TDG Rocks!
97UTPSD's Avatar
i watched the movie for sd looks like it took maybe an hour. but i looked over the instuctions and looks somewhat time consuming.
ido maint. for a living so i know i can do it. i work with gearboxes motors chain and rubber belts. but i work 12hrs and commute 2 so leaves 10 aday for sleep and family time. and saturdays are catch up on sleep and family so in order to work on truck i need kitchen pass so anybody could gives som start to burnin tires time that would be sweet. and one more thing is it acetone he used to clean contacts? i can't remember. thanks
The Rig:
1997 ford ex cab lb. dp tuner f5 DIY intake MBRP 4" 285/75 R16 kickin stereo...
tdg BOMB squad #0
singles #137
Outlaw#21
Amsoil
97UTPSD is offline
post #2 of 9 (permalink) Old 03-21-2008, 04:53 AM
powerstroke2003's Avatar
Yes, finger nail polish remover, which is basically acetone. It to me about 1.5 hrs to install the longest part was it took 45 minutes cause I was slow.
I'm Zac
2003 F-250 6.0 Powerstroke, Torqueshift, 4x4
Crew Cab, Shortbed, Dark Red Exterior; Tan Interior; H-11 Headstuds; Tuned by Innovative Diesel; MBRP down pipe straight into a 6 inch Grand Rock miter stack; Airaid Intake; Isspro Trans temp, Fuel pressure, Boost, Pyro gauges; EGR Cooler Deleted; Pro Comp 3in leveling kit and F-350 blocks out back; Eagle Alloy 114 wraped in Nitto Terra Grapplers; Ranchhand brushguard; Custom Traction Bars; Recon Smoke Cab Light and Third Brake Light;Pioneer CD Player and XM radio; and a "THE DIESEL GARAGE" sticker in the back window.
Black Betty: 1981 Jeep CJ7 258 I-6, 4 spd, Headman Header, Comp Cams MSD ignition, Motorcraft 2100 Carb, 2in of lift, 30in Swampers, Lincoln Locked rear.
Scrappy: 1975 Jeep CJ5 258 I-6, 3 spd,Headman Header, Motorcraft 2100 Carb, Full MSD ignition, Stretched 14 inches, 4 inches of lift, 33 inch tires, Lincoln Locker rear
BOMB Squad #15
Singles Club #136
American Club #17
Riding Dirty Club #25
A big thanks to Aaron at Smoking Guns Performance
powerstroke2003 is offline
post #3 of 9 (permalink) Old 03-21-2008, 09:47 AM Thread Starter
TDG Rocks!
97UTPSD's Avatar
yea i see. to me it looked like then newer SD was a bit easier. on mine i got pull the front fenderwell away and reach up there and pull out pcm.
The Rig:
tdg BOMB squad #0
singles #137
Outlaw#21
Amsoil
97UTPSD is offline
post #4 of 9 (permalink) Old 03-21-2008, 02:26 PM
TDG Mafia #76
John_DeereGreen's Avatar
I thought I remembered Diane saying that the OBS trucks were easier to install into, but I could be wrong...Good luck and let us know how you like it...
Jarrett
04.5 qcsb commonrail
Smarty TnT
John_DeereGreen is offline
post #5 of 9 (permalink) Old 03-21-2008, 03:50 PM
circle5's Avatar
took about 30 minutes to do mine
circle5 is offline
post #6 of 9 (permalink) Old 03-22-2008, 01:41 PM
git-r-done
TSGS69400's Avatar
I think that the computer on the OBS trucks in under the hood and above the driver side fenderwell.
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #7 of 9 (permalink) Old 03-22-2008, 09:27 PM Thread Starter
TDG Rocks!
97UTPSD's Avatar
yea well its done!!! way better than whatever superchips thing was installed. probly took me 2 hrs. because i made sure i followed every step in the book thing and well there were 6 not 2 screws that held the splash gaurd on so lost half hour messin with that. but overall MISSION ACCOMPLISED. THANKS DP_TUNER. I love you!!!
The Rig:
tdg BOMB squad #0
singles #137
Outlaw#21
Amsoil
97UTPSD is offline
post #8 of 9 (permalink) Old 03-24-2008, 07:25 PM
BJS
took me about 30 to put my chip in, it'll take you 5 if someone's had a chip in the truck before just pull off the ebrake pedal assy and you see the back of the PCM where the chip plugs in.
BJS is offline
post #9 of 9 (permalink) Old 03-24-2008, 11:08 PM Thread Starter
TDG Rocks!
97UTPSD's Avatar
yeah but the other person had the reprogrammer so i had to clean off the pcm.
The Rig:
tdg BOMB squad #0
singles #137
Outlaw#21
Amsoil
97UTPSD is offline
