140 ex. 140agg? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3rambaler, this thread has received 5 replies and been viewed 1282 times.
post #1 of 6 (permalink) Old 07-12-2009, 04:13 AM Thread Starter
7.3rambaler's Avatar
140 ex. 140agg?
how much more does the 140 aggressive smoke than the 140 extreme? on a DP tuner.
thanks
2000 F-250 7.3L. Ext Cab. Short Box.
Dp Tuner 80 eco-tune
Fully Built Tranny with Triple Disk Converter
AFE stage 2, 4in from turbo back stright pipe, foil Delete, X-Wheel Gauges-tranny-pryo-boost
7.3rambaler is offline
post #2 of 6 (permalink) Old 07-13-2009, 10:18 PM
CSIPSD's Avatar
UGH... 140hp setting is a 140hp setting. You will never be able to tell the differance.
CSIPSD is offline
post #3 of 6 (permalink) Old 07-13-2009, 11:03 PM Thread Starter
i know but isint the aggressive tune supposed to be more of a smoke setting..and fuels alot more down low before the turbo catches
post #4 of 6 (permalink) Old 07-13-2009, 11:09 PM
CSIPSD's Avatar
Like I said above, there are only so many ways to skin a cat. With any 140 setting there is only so much ICP to give, so much fuel there.
Notice not one other tuner out there calls out 3-4 differant 140hp settings. They also have a smoke setting, or they do until they get PC like the rest of the world.
CSIPSD is offline
post #5 of 6 (permalink) Old 07-14-2009, 12:10 AM Thread Starter
gotcha alright, thanks
post #6 of 6 (permalink) Old 07-15-2009, 10:01 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
thanks
7.3rambaler,
Basicly 140A and 140E are the same tune with more fueling in the 140A on the bottom. The power will come on stronger out of the hole with the 140A. How strong on the top end on both will be depends on how strong or weak your HPOP is.
Diane
SeeYa is offline
The Following 2 Users Say Thank You to SeeYa For this addition to TDG:
7.3rambaler (07-16-2009), Deputydog (07-16-2009)
