? about icp pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droolinforparts, this thread has received 7 replies and been viewed 1688 times.
post #1 of 8 (permalink) Old 09-16-2009, 02:28 AM Thread Starter
droolinforparts's Avatar
Send a message via AIM to droolinforparts
ok so i was talking to a guy out here at collage and his 99 lopes like all hel*...i dont no much about the 7.3 cuz im a 6.0 guy but he said he turned up the icp press. is that even possible and safe?
'03 F250 XL 6.0LK&N intake, mbrp 5" stacks, SCT X3 with tunes from innovative, 6" superlift, 315-75r-16,boost, pyro, fuel pressure, oil pressure gauges all in the a-pillar,h-11 studs, short throw shifter,fass 95/150 with complete custom fuel lines, south bend clutch, traction bars
Singles #118
B.O.M.B Squad #28
droolinforparts is offline
post #2 of 8 (permalink) Old 09-16-2009, 03:52 AM
Turning up the ICP pressure at idle (either through a fooler or through programming) will make it lope. Some tuners will sell a lope tune for their chips. Me personally, I'm not a big fan of making a diesel sound like a cam'ed out big block, but others like it, so let them go for it. It's just at idle, so it's not going to hurt anything.
Pocket is offline
post #3 of 8 (permalink) Old 09-16-2009, 10:28 AM Thread Starter
ok...i would like to get my 6.0 do it cuz i am one that likes how it sounds but i want to do it with a cam....not electronically
Singles #118
B.O.M.B Squad #28
post #4 of 8 (permalink) Old 09-16-2009, 02:50 PM
If you achieve a lope at idle on a diesel because of a cam, you're going to have major problems.
Pocket is offline
post #5 of 8 (permalink) Old 09-16-2009, 04:32 PM Thread Starter
really?.....how so?
Singles #118
B.O.M.B Squad #28
post #6 of 8 (permalink) Old 09-17-2009, 01:41 AM
SmokeCloud's Avatar
You can either bump up the injectors, or change the resistor in the ICP sensor.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #7 of 8 (permalink) Old 09-17-2009, 06:28 AM
really?.....how so?
Think about the difference between a gas engine and a diesel, and how they are fueled differently.
Gas engines pump fuel out of injectors (or carburetor) into the intake runners. So the mixed air and fuel enters the cylinders at the same time. Change the cam duration, and you change the fueling rate.
Diesels pump fuel directly into the cylinders, but only at the exact point of ignition, so the air has already been drawn in and was waiting. So they enter the cylinders at different times. Change the cam duration, and the only thing you affect is airflow. Fueling rate remains unchanged.
Now in order to get a diesel to lope due to airflow, would be to severely restrict the airflow to the point of choking out the engine. This would result in some big problems.
Hopefully now you can see why you can't achieve a big block style lope idle with just a cam on a diesel.
Pocket is offline
post #8 of 8 (permalink) Old 09-17-2009, 10:33 AM Thread Starter
yea....never thought about it that way
Singles #118
B.O.M.B Squad #28
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Any way to boost Low pressure oil pressure? CSIPSD 1994-2003 7.3L Power Stroke 6 10-10-2006 01:15 AM
anyone doing fuel pressure or oil pressure skinz0021 General Dodge Discussion 7 08-19-2006 02:42 PM
