98 powerstroke tuner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdyess, this thread has received 2 replies and been viewed 764 times.
post #1 of 3 (permalink) Old 10-14-2009, 06:32 PM Thread Starter
My buddy just bought a 98 econoline van with powerstroke and needs a tuner that has option of changing tire size to correct speedometer. Any sugestions?
jdyess is offline
post #2 of 3 (permalink) Old 10-15-2009, 09:43 PM
BJS
the speedometer can be corrected without a tuner, search "Ford PSOM reprogram" on here and google you'll get the results you need on how to reprogram it.
As for the tuner, look into a chip from any variety of manufacturers and gauges are highly recommended for any power adders.
BJS is offline
post #3 of 3 (permalink) Old 10-16-2009, 05:20 PM
The one and only
Only way to reset the speed-O is with AE or a Ford reporgram.
As for a chip I would get one from Matt at Gearhead or Bill at PHP
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
ppe tuner for 08 powerstroke 08powerstroke 2008-2010 6.4L Engine Tuner Forum 33 01-19-2008 09:10 PM
I need a Tuner for my 06 f 250 powerstroke turbo lee boy 1994-2003 7.3L Chips & Tuners Forum 1 12-23-2006 02:24 PM
OBS Powerstroke Swap to SD Powerstroke Question Dieselwrencher 1994-2003 7.3L Power Stroke 6 12-02-2006 02:30 AM
Best tuner or chip for a 97 F250 powerstroke Jaadc01 1994-2003 7.3L Power Stroke 5 04-26-2006 04:44 PM
Powerstroke Superchips Tuner Tim @ P.I.S. Whats Been Sold 11 04-04-2006 04:28 AM
