24 valve P pump timing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by deere puller, this thread has received 12 replies and been viewed 10084 times.
post #1 of 13 (permalink) Old 02-24-2007, 08:59 PM Thread Starter
Send a message via AIM to deere puller Send a message via Yahoo to deere puller
What would a good timing be for a 24 valve with a p pump, Ive had alot of people and shops tell me 16 to 19 but a couple tell me up to 25. Im having alot of trouble getting this thing to run right and wondered what others are at. Its at 21 right now.
deere puller is offline
post #2 of 13 (permalink) Old 02-24-2007, 09:32 PM
diesel_ram_man's Avatar
Images: 6
It kinda depends what your going to use the truck for. And do you have your head studed and/or o-ring'd?
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #3 of 13 (permalink) Old 02-25-2007, 01:05 AM
what other settings have you tried? I would personally start low and work your way up. Its kind of time consuming but it will vary from truck to truck, depending upon mods and what fuel you are using. I'd try running a lot closer to 16. Unless you have studs, I think that 21 is way too much. That will be pretty hard on the street.
post #4 of 13 (permalink) Old 02-25-2007, 02:45 AM
Cummins Man
Dazedandconfused's Avatar
There are a few 12valves here running up close to 25* but they are studed and ringed.
Andy
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #5 of 13 (permalink) Old 02-25-2007, 04:06 PM
Yeah, they probably aren't very street friendly either. highest I've heard of on a 12v was about 26-28*. 16-18 should be good with moderate to semi high fuel. It may smoke a little more, but I think it will run and idle a lot smoother and be more drivable.
post #6 of 13 (permalink) Old 02-25-2007, 04:20 PM Thread Starter
Ya its not very good on the street, and thats all it will be used for. It is studded but not oringed, and has a pretty good pump on it and 155 bd injectors.
post #7 of 13 (permalink) Old 02-25-2007, 04:39 PM
DPS
Is your pump stock? Has it been calibrated recently? What kind of drivability complaint do you have? It may not be a timing problem, there are other adjustments in the pump that effect drivability more.
DPS is offline
post #8 of 13 (permalink) Old 02-25-2007, 04:51 PM
Cummins Man
600+hp daily driver. I have not heard any complaints about driveability.
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
post #9 of 13 (permalink) Old 02-25-2007, 05:05 PM
DPS
Questions directed at Deere Puller
My previous questions were directed to the post that started the thread and the drivability part was related to the fact that deere puller says "Im having alot of trouble getting this thing to run right"
DPS is offline
post #10 of 13 (permalink) Old 03-01-2007, 02:30 AM Thread Starter
The pump is not stock, it was on a friends truck for a few months, but his was a 12v. It has bigger barrels and plungers, dif cam, and 4K gov springs, It ran good on his truck, but now is hard to start(has to be cranked alot longer than it should), when giving it light throttle it wnats to take off( like you are pushing alot harder than you are) jsut really jumpy, and it doesnt want to idle smooth part of the time. other than the pump, the motor has 50 horse injectors( which I have ordered new 155 ones but dont have them in yet, the old ones have alot of miles on them and jsut wonder if they are getting worn out and kinda think one may be sticking),and a hx 50 hybrid charger. thanks for any help
