Another lift pump question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jaredm, this thread has received 5 replies and been viewed 780 times.
post #1 of 6 (permalink) Old 03-20-2007, 07:25 PM Thread Starter
hi im kinda new at this so i hope im putting this in the rite place. does anyone out there know anything about the BD lift pump kits on Extremediesel.com? its looks like a good deal but im not sure if i should do that or just buy a holley blue at o'riellys and plump and wire it myself (FASS is too rich for my blood). also, should i leave the stock lp on or take it off? any advice will help, thanks!
'99 ctd 6spd 4x4 edge comp, k&n, st8 pipe, silencer ring m.i.a., leveling kit, and guages.
soon to come: bhaf, and hopefully injectors. (and a lot of black SMOKE!)
:smoke
jaredm is offline
post #2 of 6 (permalink) Old 03-22-2007, 03:58 AM
tbroadus_41's Avatar
i bought a fass for my truck and i'm going to install it like my buddy had industrial injection do on his truck and leave the stocker on there in case anything happens to the fass, a few small hose and wire changes and you can still get home.
tbroadus_41 is offline
post #3 of 6 (permalink) Old 04-08-2007, 02:43 PM
2nd Gen Guru
Mopar1973Man's Avatar
Here is the two write ups I got on fuel systems....
http://www.frontiernet.net/~mopar197...paign_pump.htm
http://www.frontiernet.net/~mopar197...n_big_line.htm
Both of these I done very well with pressure. I normally hold 12 PSI on the run and about 10-11 PSI on the WOT.
Mopar1973Man is offline
post #4 of 6 (permalink) Old 04-15-2007, 05:18 AM
What kind of prices are you getting for these lift pumps i can get a fass pump without filters for $425 plus shipping.
Chop342 is offline
post #5 of 6 (permalink) Old 04-19-2007, 03:13 AM
i picked up my fass 150 gph pump for $401 shipped to my door.
post #6 of 6 (permalink) Old 04-19-2007, 03:33 AM
thats not to bad you did really well i sell just under the MAP to try and stay out of troubles with DPP but $401 is really sweet you made a really good buy!
Chop342 is offline
