Best Injectors?????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jktcummins, this thread has received 12 replies and been viewed 3742 times.
post #1 of 13 (permalink) Old 03-29-2007, 06:37 AM Thread Starter
Has anyone tried the bully dog injectors. I found some for step 8's for under $800.
Does anyone have any favorites???? I have ran both stage 2 and stage 4 jammers and i am really not to impressed with them. I just thought i would see if anyone has any recommendations. I am wanting to hit the 500 to 600 hp range. Right now before the cam i was at 425hp. Fixing to try and get my head fireringed and ported.
Surely with some bigger injectors, possibly bigger connecting tubes, Redline box, s300 64/14 on top of a HTB3, Heavy duty valve springs and titanium retainers i will be able to hit some were in that 500 o 600 range?????
Also is there any single turbos out there that will support that HP range and wont be too laggy????
2002 dodge 2500 4x4, ATS stage 5 tranny, ATS billet flexplate, ATS torque commander, ARP headstuds, BHAF, custom S300 64/14 turbo, Big FASS fuel system, Industrial 10 holes, .093 tubes, Edge juice w/ attitude, smarty, Haisley streep puller cam, Hamilton Diesel head and orings, PDR valve springs, ATS exhaust manifold, Gauges, 285/75/16 BFG allterrians, front and rear replacements, and 5" exhaust.
:smoke '95 3500 4x4 dually red
raymac racing engine, big cam, fly cut pistons, 650cc pump, 26* timing, 5x18 EDM injectors, industrial s400
jktcummins is offline
post #2 of 13 (permalink) Old 03-29-2007, 11:28 AM
sorry to thread jack but what did those jammers do to your fuel milage? im in the market for some stage 3 sticks but dont want to kill my milage.
suzy q is offline
post #3 of 13 (permalink) Old 03-29-2007, 05:17 PM Thread Starter
I really couldnt tell you i pull so damn much i never really get to get a full tank just driving. I get anywhere from 10 to 14 pulling. If you want to try some i have a set of stage 2 and a set of 4 for sale.
post #4 of 13 (permalink) Old 03-29-2007, 09:16 PM
diesel_ram_man's Avatar
Images: 6
DonM's Mach series seem to be very popular. But a little on the expensive side.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #5 of 13 (permalink) Old 03-29-2007, 09:38 PM
Cummins Man
Dazedandconfused's Avatar
DDP is the best injector on the market for the 24V right now in my opinion. There is a guy that just put a set of 150Hp DDP's in his truck and took out the stage five jammers. Truck runs stronger, smoother and not as hot. I've heard a guy put in a set of Stage 5 DDP's and they dynoed 10hp more then the Mach 6 injector. I plan to go with DDP injectors in mine.
Andy
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #6 of 13 (permalink) Old 03-29-2007, 09:45 PM
D_B
Andy
Yep!
I've been up and down the full range of injectors for a 24valve. By far the best I have ran are the Mach injectors from Don. Don's injectors are very clean burning for the size and seem to be easier on EGT's as well. So far I haven't seen anyone have a better spray pattern that what Don is getting out of the Mach injectors. I haven't had any experiance with the DDP's but hear lots of good things about them as well. I would say if I was buying another set Don's would be first on my list and then the DDP's. If I was trying to save a little $$$$$ then I would got with the DDP's first.
DB
DB
1999 Dodge Ram 2500 LWB, Intense Blue, 5spd,
4:10's, all kinds of goodies and doodads!
NRA Lifer
D_B is offline
post #7 of 13 (permalink) Old 03-29-2007, 10:28 PM
Don M's are a really nice injector. You should be able to do very well with that set up and a set of mach 6-8 injectors. Mach 8's, Nitrous, B1, Edge comp, Redline, Hilux 2, and HRVP44 made 832hp. Thats a nice number for a 24v right there. Not sure if there was any other head work.
I talked to a guy that ran those bully dog stage 8's, and didn't like them as much as the Mach 5's he has now. I know someone else that ran those in his old truck a couple years ago and liked them.
post #8 of 13 (permalink) Old 03-30-2007, 02:14 AM
Trouble Maker
Bully dog injectors are junk.
They are a large 7 hole with a terrible spray pattern and poor fuel atomization.
The BD 8's will smoke black at idle.
MKoth is offline
post #9 of 13 (permalink) Old 03-30-2007, 02:42 AM Thread Starter
WEll thats what i was kindof think about the bully dog injectors. Has anyone on here tried any of haisley's injectors. I am so impressed with their cam that i have been considering going with them for the injectors. But i havent heard anyone that has used them.
I have heard a lot about the Mach injectors and have a friend with some Mach 7's. That truck is a running son of a gun.
So what size mach's or DDP should i run.
This is my problem i have heard good things about both. But i want more.
post #10 of 13 (permalink) Old 03-30-2007, 11:53 PM
Images: 6
Mach 6's are a popular choice for twinned trucks. Some guys are even running the Mach 7's w/ twins.
Can You Keep Up??
