6.7L Pistons in early 24 Valve Engine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ewales, this thread has received 5 replies and been viewed 1533 times.
post #1 of 6 (permalink) Old 02-22-2010, 11:11 PM Thread Starter
Hi
I have recently heard that the pistons from a 6.7L can be used in an earlier 5.9L 24 V for better performance. Can anyone point me in the direction of more info on this ?
Thanks
ewales is offline
post #2 of 6 (permalink) Old 02-23-2010, 04:07 PM
Why do you want to change the pistons? If you are just wanting more performance what have you all ready done and how much do you want.
later is offline
post #3 of 6 (permalink) Old 02-23-2010, 04:17 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Yes they are making Hybrids between 5.9 and 6.7 parts pistons, rods, cranks
Military Quote Of The Year
SOOTBANDIT is offline
post #4 of 6 (permalink) Old 03-09-2010, 02:46 AM
Yeah, I've been thinking of trying to stroke my 5.9L out to a 6.7L one day. It would be pretty sweet. I'm not sure how the spray patterns are though. If they are different, then you may need a different nozzle to work properly with the 6.7L pistons.
post #5 of 6 (permalink) Old 03-09-2010, 09:11 AM
The 6.7 has both a different bore and stroke. You could stroke it but I question boring that far.
later is offline
post #6 of 6 (permalink) Old 03-09-2010, 11:30 AM
PhilipR's Avatar
Are the main and rods the same on the 6.7 as the 5.9? Meaning will the 6.7 crank drop right in and the rods bolt up? Custom pistons would be required to lower the pin height for the increased stroke but you could have a set made with 12V bowls.
-Phil-
PhilipR is offline
12 valve engine parts SPLnut Whats Been Sold 11 04-25-2010 01:09 AM
6.0 Pistons and valve springs Gibson Ford Parts 9 11-15-2009 08:06 PM
1999 24 valve engine Bone stock 99 Whats Been Sold 4 06-17-2009 05:43 AM
Lots of early 99 engine parts.... 6Gears Whats Been Sold 26 03-31-2009 09:15 PM
Is a 89 Mack E6 a 2 or 4 valve engine? 2006copperPSD Medium and Heavy Duty 8 01-22-2008 10:32 PM
