tuner question? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ehopp88ss, this thread has received 21 replies and been viewed 7841 times.
post #1 of 22 (permalink) Old 06-17-2010, 04:22 PM Thread Starter
2004.5 Dodge Ram 2500
ehopp88ss's Avatar
tuner question?
what is a pressure box tuner? isnt there another kind other than that? just curious. im new to the whole tuner thing. just doing some research.
thanks
erik
Erik
My Vehicles
2004.5 Dodge Ram 2500 4X4 QCLB, NV5600, 177K miles, 10000k HIDS, FASS 150, EDGE juice w/ attitude "HOT UNLOCK", VALAIR 650HP DD thanks to DAN'S DIESEL PERFORMANCE!
1988 Monte Carlo SS, 305 SBC, true dual 2.25" t-304 Stainless exhaust, T-Tops, custom red pryzmatique paint, 2 12" Alpine Type-R Subwoofers, 500 Watt Alpine amp, Alpine speakers inside, complete 2 year ground up restoration, 22K miles on rebuild
ehopp88ss is offline
post #2 of 22 (permalink) Old 06-17-2010, 04:53 PM
PhilipR's Avatar
A pressure box deals with the injection side of things by changing the pulse width and rail pressure for the injectors. Where a timing box will adjust the timing of the injection events. A Smarty does both IIRC....The reason some are listed as one or the other is so you can stack them as you don't want two boxes doing the same thing. I'm a 12V guy so I might be wrong though .
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
ehopp88ss (06-17-2010)
post #3 of 22 (permalink) Old 06-17-2010, 06:21 PM Thread Starter
ehopp88ss's Avatar
ooo. well in your opinon what is the best? stacking is probably the best right? what is the best after that though?
Erik
My Vehicles
post #4 of 22 (permalink) Old 06-17-2010, 09:51 PM
ADMIN/MAFIA
neeltburn's Avatar
Stacking can be dangerous, if your gonna stack anything on your truck the best combo IMHO is Smarty with MP-8. But your gonna toast your clutch. If I where in your shoes Erik I would look at the Smarty Jr. for your rig, it with have a good mileage tune, tow tune and performance tune. Its a downloader style tuner that you put on the truck. Your gonna need a lift pump to supply fuel if you stack on your rig to keep the fuel supplied to the CP3 so you don't run the risk of draining the rail. Also before you get a tuner, get your gauges put in so you can keep an eye on whats going on.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 22 (permalink) Old 06-17-2010, 09:57 PM
ADMIN/MAFIA
neeltburn's Avatar
Aaron explains the tuners well in this post Check this out
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 22 (permalink) Old 06-18-2010, 12:11 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
I agree with Neel, a simple tuner like the Smarty Jr. or Diablosport predator are going to give you the best 'bang for your buck' especially since i know you dont have a lot of $$$$$ the predator can be had for under $400, and i think the smarty jr. is just over $400
Stacking on a dodge is the current way to make the best power, the best Combo's so far it seems are Smarty TNT Revo POD with TS MP8, or Smarty TNT Revo POD with the TST CR 45, both will smoke your stock clutch, stock turbo, and stock CP3 with zero effort
Like Neel also said stacking boxes, especially when you dont know what your doing in regards to which tuner/box/programmer is providing injection timing, fuel pressure, commanded fuel, boost pressures, etc. you can blow up your motor, just ask Sledpuller500(Erik), he had THREE different power adders on his truck and melted it down
In the near future the best tuning options for the 5.9L CR Cummins will be with a little programmer called EFI Live...... but I dont know anything about that
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #7 of 22 (permalink) Old 06-18-2010, 02:35 AM Thread Starter
ehopp88ss's Avatar
are you serious about the efi live? do they have that for dodge? i know they have it for the chevies because of ur sig and my buddy has it as well
Erik
My Vehicles
post #8 of 22 (permalink) Old 06-18-2010, 02:36 AM Thread Starter
ehopp88ss's Avatar
so what you guys are saying is that if i were to do anything i should NOT stack anything until i get a new LP and injectors and clutch and all that good stuff?
you are recomending the smarty? or the smarty JR?
thanks guys
Erik
My Vehicles
post #9 of 22 (permalink) Old 06-18-2010, 03:33 AM
ADMIN/MAFIA
neeltburn's Avatar
EFI Live has starting tuning for 07.5 6.7L and I believe the 06 CR but they use a CANBUS ECM so the tuning for your rig may be a while waiting on EFI Live. See in 06 Dodge changed the way they programmed the ECM as a test for the up coming 6.7L. This is why you see the S-06 Smarty and then the other one for the CR.
thanks guys
The Smarty SR is 685 and the Jr is around 500. The 100hp tune on the JR. is going hurt the clutch enough. Unless you plan to go all out with you rig in the long run then I would ( I have the S67 Jr.) go the Jr. Like I said earlier the jr has a tune for every need though it may not be the hottest and baddest tune it will work. just my .02s
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 22 (permalink) Old 06-18-2010, 04:19 AM Thread Starter
ehopp88ss's Avatar
so there is a chance i could hurt my truck with the JR if im dumb and try to go fast with it? i just want it to get a little better fuel mileage and the occasional puff of the goodie good black stuff
Erik
My Vehicles
SCT tuner question Hellbilly 2008-2010 6.4L Engine Tuner Forum 5 10-19-2009 05:00 AM
Tuner question Thrillbilly 2003-2007 6.0L Power Stroke 9 12-06-2007 02:12 PM
Tuner question mfd60 2003-2007 6.0 Tuner Forum 15 05-14-2007 10:04 PM
Tuner question... $DIESEL 2003-2007 6.0 Tuner Forum 21 11-23-2006 07:55 PM
SCT Tuner Question Dieselwrencher 2003-2007 6.0 Tuner Forum 15 11-20-2006 04:18 AM
