Who's running a BD Exaust Manifold? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SteveinAK, this thread has received 8 replies and been viewed 1458 times.
post #1 of 9 (permalink) Old 08-24-2006, 12:06 PM Thread Starter
Wow, guess I'm first to post in this part of the forum! Cool! :Thumbup: Anyway, anbody runing this manifold? It's going to be either this or the ATS. Any reason to choose one over the other? Any real perfomance gains with it and how about drop in EGT's?
SteveinAK is offline
post #2 of 9 (permalink) Old 08-26-2006, 03:46 AM
BigDodge's Avatar
i had 1 on my 04 for 2 years and just put 1 on my 00 3500. 2000 3500 seems to spool quicker and egt's are about 125deg's lower at 70mph. plus they don't crack like the stock ones do.
96 2500 215 pump,CompR62,DDP3's,suncoast convter,6'lift
96 3500 12v auto,Bullseye CompR62 DDP3's,suncoast converter
95 1500 318 auto "for now"
99 1500 360 auto "for now"
95 1500 Bullseye Powered P-Pumped 24v. [email protected]
BigDodge is offline
post #3 of 9 (permalink) Old 09-18-2006, 04:01 AM
I am running an ATS 2 piece. Real nice.
slowcummins is offline
post #4 of 9 (permalink) Old 09-24-2006, 05:53 PM
The nice thing about the BD is its already tapped and plugged for a Pyro. Either one is good and either on is about the same price. I have run both. I have the older twins seet that BD sent out with the ATS. It has worked fine. The last set of BD turbos I installed had the BD manifold. I think the flanges on the BD are cleaner.
Diesel Nut is offline
post #5 of 9 (permalink) Old 09-24-2006, 11:29 PM
Bouncer
HTT also makes a very nice manifold that comes pre-drilled.
post #6 of 9 (permalink) Old 10-30-2006, 03:07 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
I am also running the ATS manifold on my 04.5. Turbo spools up a lot faster and is a lot louder now. Definetly a nice piece.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #7 of 9 (permalink) Old 11-12-2006, 03:05 PM
The ATS is now being shipped assembled,drilled and tapped and also coated in black.
Bob
bob4x4 is offline
post #8 of 9 (permalink) Old 02-28-2007, 04:53 PM
Bob
Yep, you are correct, and along with that came a big price increase!
post #9 of 9 (permalink) Old 03-19-2007, 01:51 AM
funny thing is I ordered a bd 2 piece for my 03 and it came in as an ats in 2 SEPARATE pieces, but it was easy to assemble and was pre-drilled
2003 S.O. nv4500, SB "iron giant" DD clutch, HOT Juice w/attitude, revo smarty, straight pipe, 5"silverline miters, homemade air intake,ATS manifold, S400 Turbo, fire ringed head, upgraded valve springs, scheid 100hp inj, psi fuel system, wicked diesel arson cp3 kit, regrind cam, column mounted phantom 100lb boost and 2000*pyro, snow water meth kit
NOT ANYMORE BC I SOLD IT!
Scotty_G is offline
