Air Intake? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jw_hendry, this thread has received 24 replies and been viewed 6058 times.
post #1 of 25 (permalink) Old 08-02-2007, 02:15 AM Thread Starter
Air Intake?
What kind of air intake would work best for an '05 Cummins. I drive a lot of dirt roads so it'd have to be super tough and probably pre-filtered. I also want it the turbo to scream, took silencer ring out and didn't seem to do much. Any suggestions would be great. :thanks:
jw_hendry is offline
post #2 of 25 (permalink) Old 08-03-2007, 10:29 PM
I'd stick with the stock intake if you're off road that much. Look into amsoil's drop in nanofiber filter if you want ease of cleaning and good filtration.
here is the link to the filter / part # that should fit your vehicle.
http://www.amsoil.com/storefront/detail.aspx?ID=6861
jlibert is offline
post #3 of 25 (permalink) Old 08-28-2007, 04:21 PM
Go with the AFE stage II pro guard 7 with a precleaner wrap
imported_Prodiesel is offline
post #4 of 25 (permalink) Old 08-29-2007, 04:01 PM
go for a dry filter. they are relatively new and im not sure how many people actually like them but I love mine. The dry filters only have to be put in a bucket of warm water. Just dunk it and work it around then let dry. Once dry put back in and your ready to go. I have the AEM Bruteforce, but i would recomend an intake with a box because the exposed filter will get dirtier a lot faster then with a box. Volant and S&B have enclosed boxes.
silvrcummns is offline
post #5 of 25 (permalink) Old 08-29-2007, 09:52 PM
I have a brand new one of these for sale if your interested jw_hendry.:Thumbup:
PonymanfiveO is offline
post #6 of 25 (permalink) Old 08-30-2007, 05:42 PM
CumminsPower's Avatar
Bhaf with a prefilter. Heres mine
CumminsPower is offline
post #7 of 25 (permalink) Old 08-30-2007, 06:26 PM
I had the BHAF on my 12V'er
BigD
BigDBP is offline
post #8 of 25 (permalink) Old 09-04-2007, 08:08 AM
I would Go with the AFE stage 2 with the pro guard filter as long as U clean ur filter reg. and dont drowned it in oil U will be fine just check it every so often also if U put a pre filter it help with big debris and cut on the cleaning.
CPOUTLAW is offline
post #9 of 25 (permalink) Old 09-06-2007, 02:50 AM
I have the truflo drop in , and like it alot. I have yet to see any dust after the filter.
06TRX is offline
post #10 of 25 (permalink) Old 11-09-2007, 04:01 PM
Crew Chief
XLR8R's Avatar
I fabbed a super BHAF at the shop - enough Cummins-spec air flow & filtration to support over 900HP & almost 2000 ft-lbs. of torque.
3 Nails Garage
Sleeps 3 Rams, 1 G8 & a Goat
GUN-HAPPY Crew Chief
XLR8R is offline
