cp3 drain - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cajuncummins, this thread has received 10 replies and been viewed 1803 times.
post #1 of 11 (permalink) Old 09-06-2007, 09:23 PM Thread Starter
cp3 drain
How much horsepower would cause the fuel rail to be drained, and how much before a hot-rodded cp3 would fall short too?
cajuncummins is offline
post #2 of 11 (permalink) Old 09-06-2007, 09:48 PM
i think anything around 160hp can start leaving the rail a tad dry. but usually you'ld want to change the lift pump(from tank to cp3) before upgrading your cp3 because if the cp3 can't get enough fuel then the rail won't get all the fuel but with an upgraded lift pump you should have enough fuel pressure in the rail. maybe if u had big injectors and a big tuner you would need to ugrade the cp3 then.
silvrcummns is offline
post #3 of 11 (permalink) Old 09-07-2007, 03:56 AM
Mafia member 46
In my truck just the TST PMCR can drain my rail on 5/5 and(about 100 hp) a VA C3.1 pressure box allowed 5/5 to make about 200 over stock. I now have F1 Flux 2.5's(rated @ anout 125hp.) and an MP8 and can only use the TST on 2-2 without completely draining the rail. I REALLY need a stage 2 modded pump!
the only reason my #'s are so low is I like lowend (that is where I spend almost all my time) if I was to lower the Tq. value and raise the hp value I would turn higher #'s but would lose the torque I love.
Current: '07.5 2500 QC/SB ETJ/68RFE, 4x4, Fabtech 6" lift, KMC XD "Diesel" 20x10 wheels, Pro Comp X all terrain 37x13.5R20 tires, BDog P Pup AFE, MegacannonII, H&S Gen 1 DPF Delete, EGR unplugged. Dynoed 361hp/677tq 20090220
SOLD!'03.5 3500 SRW QC Dynoed 2/11/06 457hp/1002tq
Scrappy is offline
post #4 of 11 (permalink) Old 10-30-2007, 02:48 PM
Bragg
Send a message via Yahoo to kino_fab
you can get a CP3 modifing kit from psi components. http://www.psicomponents.com Its called the the CP3 Arson kit. Its only about $300 or so and you do not even have to remove the CP3 from the truck. Get that and a good FASS or Glacier fuel system and you should be good for an extra 300hp if not more.
R.I.P. Jamie Curtis Adams:smoke
04.5 Dodge 3500 Dually. 325 CTD, 6speed, 4x4, Black and Chrome.II Silver 62, TST PMCR R49, Hamilton 110lb Valve springs, Straight Piped, ValAir 12CB Dual Disk Clutch, ATS Pulse Flow Manifold, Raptor 150 Fuel System, ARP headstuds, AEM Brute Force, 17X9 RaceLine Renegades wraped in 285/70-17 Mickey Thompson ATZ's
Soon to come: DIY CP3, Modded Rail, Smarty TNT.
kino_fab is offline
post #5 of 11 (permalink) Old 10-31-2007, 02:39 AM
Mafia member 46
I have done the DIY CP3 mods and can run one extra level on the TST but can still drain the rail. I am itching to get on the dyno and see what my new mods have given me. I hope to finally break 500(out 0f an 03.5 HO)
I am trying to save up the money for a Floorit stage 2 pump but it isn't going too well so far!
Scrappy is offline
post #6 of 11 (permalink) Old 11-09-2007, 04:22 PM
Crew Chief
XLR8R's Avatar
The in-tank LP helps the fuel delivery to the CP3 quite a bit for the HPCRs... it's better to blow than suck!
Need over 500HP of fueling to start draining the rail on '05+
3 Nails Garage
Sleeps 3 Rams, 1 G8 & a Goat
GUN-HAPPY Crew Chief
XLR8R is offline
post #7 of 11 (permalink) Old 11-11-2007, 03:29 AM
Hello, new to forum. Anyone here had problems not being able to start, but getting fuel through to injectors?
mikeshauling is offline
post #8 of 11 (permalink) Old 11-11-2007, 03:42 AM
anyone help me find out more on not starting but getting fuel to injectors
post #9 of 11 (permalink) Old 01-22-2008, 01:57 PM
look here for discussion on modded cp3's
http://www.competitiondiesel.com/for...ad.php?t=19754
feelmecummin is offline
post #10 of 11 (permalink) Old 01-22-2008, 10:31 PM
Crew Chief
XLR8R's Avatar
... and don't forget to put your boots on. :splat
3 Nails Garage
XLR8R is offline
