Question about the pyro for Edge. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Racing41, this thread has received 5 replies and been viewed 1024 times.
post #1 of 6 (permalink) Old 10-14-2007, 04:17 PM Thread Starter
I just got my Edge Juice with Attitude. I already have the pyro thats on my other gauges. Can I just tap into the wire and hook them up together or do I need to redrill another pyro hole? If I can just wire it in. please inform me on how to do so. Thanks
Racing41 is offline
post #2 of 6 (permalink) Old 10-20-2007, 06:03 PM
word on the street is....its a bad idea. It has worked before but theres also been some messed up pyro readings from trying this.
I always put the second pyro post turbo for a comparison of pre to post turbo EGTs.
973604x4 is offline
post #3 of 6 (permalink) Old 10-20-2007, 08:22 PM
Kip
In the passing lane
Kip's Avatar
I have had mine both done with one for about 3 years now with no poblems at all. I would Have to look for sure but if I remember right I ran the on that came with the attitude up to were the box is and then split them from there. I can look tomorrow
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #4 of 6 (permalink) Old 11-09-2007, 04:33 PM
Crew Chief
XLR8R's Avatar
Type K thermocouples are calibrated for their length, so splicing into an existing cold junction can cause accuracy issues - but probably not an issue unless you require NIST standards.
Unless you just want an auxiliary EGT gauge, you might consider using it as a pre-CAC temp gauge... can be a handy tuning aid!
3 Nails Garage
Sleeps 3 Rams, 1 G8 & a Goat
GUN-HAPPY Crew Chief
XLR8R is offline
post #5 of 6 (permalink) Old 02-21-2008, 01:14 AM
well another option you have is what size is the pyro you already have? if its the same drill sized hole, and the thermocoupler is tapped with a 1/8 npt, then why not just take the other probe out of the coupler, and screw the one with the edge into, remember the coupler is whats already in your maniflod, not the pyro, the probe should just drop into the other coupler, and screw right in... just my :2cents
SOUTHERN SMOKE is offline
post #6 of 6 (permalink) Old 02-24-2008, 11:44 PM
Kummins's Avatar
Some people like pre turbo (that's where you'd want the edge) and post turbo pyro readings. You could do that set up if you found that info useful.
Kummins is offline
