DIY cp3??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Quality Equip, this thread has received 4 replies and been viewed 928 times.
post #1 of 5 (permalink) Old 04-17-2008, 01:06 AM Thread Starter
DIY cp3???
I read the relentless diesel DIY cp3 up grade it is simple enough is it worth it or do you need dual feed line and injectors to see power difference also will it help with rail chatter
Quality Equip is offline
post #2 of 5 (permalink) Old 04-17-2008, 01:48 AM
pm BILLM2004 he has diy cp3 ask him how hard it was and if is worth it. he seems to having pretty good luck, but i dont thing he has enough fuel for all his mods
now own 2007 5.9 6 speed afe stage 2, ppe programmer, 5inch silverline turbo back
traded it in 01 dodge, dual disc, drag comp, head o ringed and studed, stock turbo
smokeyourdiesel is offline
post #3 of 5 (permalink) Old 04-17-2008, 02:02 AM
I read that articel, looks realy easy. But the only thing I would worry about would be the fact that your grinding on an expensive pump. I guess its just the same as a Modded CP3 from any shop. I hope it works because Im helping a buddy do it before the TS drag races!
imported_Bosshawg600 is offline
post #4 of 5 (permalink) Old 04-17-2008, 03:29 AM
unless you are going with larger injectors... you really have no reason to even upgrade it. A stock CP3 is good to around 500hp. Dual lines wouldn't do anything for you.
What kind of rail clatter are you talking about ? You shouldn't have any of that.
As mentioned... if you decide to do that mod, be very careful ! those pumps aren't cheap and it doesn't take a lot to make one a paper weight.
triton is offline
post #5 of 5 (permalink) Old 04-21-2008, 09:58 PM
TDG Singles Club Mem #57
cope junkie's Avatar
On that website would you find one?????
2006- "EFI LIVE", MP-8, Snow, 66/74, twin cp3, 250hp injectors, Fass, South Bend dd.
pushin 800hp
cope junkie is offline
