piston/injector? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JakeDiesel, this thread has received 3 replies and been viewed 1142 times.
post #1 of 4 (permalink) Old 02-15-2009, 04:15 PM Thread Starter
piston/injector?
Can u use 24v pistons in a common rail head?
If you were to p pump a common rail could you use 24v injectors?
Thankx Jake
2005 3.9 Cummins 4BTAA 94 dodge 1500 2wd A518 trans 27 mpg around town
http://www.cumminsforum.com/forum/cu...ics-truck.html
Friends 95 dodge 2500 #6 fuel plate and 35lbs of boost.
JakeDiesel is offline
post #2 of 4 (permalink) Old 02-15-2009, 04:46 PM
The injectors would have to be custom to work on a P pumped CR as the original are fired electronically and the P pump uses a poppet valve to fire the injector AFAIK.
joush is offline
post #3 of 4 (permalink) Old 02-16-2009, 03:44 AM
Of Course
Or just use the stock injectors from a '98.5-02 with the proper lines. The front case is the largest obstacle.
That Guy is offline
post #4 of 4 (permalink) Old 02-16-2009, 11:11 AM Thread Starter
I got a 12v block with a cracked head, and I would like to replace it with a cr head. Thanks guys
jake
piston above the dack? jap901 7.3L and 6.9 IDI (Pre 1994) 3 04-20-2008 12:45 PM
piston top star pattern with SCT?? dieseljunky1 2003-2007 6.0L Power Stroke 16 12-20-2007 02:30 AM
cracked piston f350bart 2003-2007 6.0L Power Stroke 6 08-09-2007 01:50 AM
466 Piston cooling nevrenufhp Medium and Heavy Duty 2 03-17-2007 03:48 PM
Piston Discussion Dieselson Duramax 2001-2004 (LB7) 0 11-30-2006 10:28 PM
