Need to know??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04.5cumminsman, this thread has received 12 replies and been viewed 2190 times.
post #1 of 13 (permalink) Old 03-08-2009, 01:26 AM Thread Starter
Send a message via Yahoo to 04.5cumminsman
Need to know???
I recently removed a BANKS 6 GUN from my truck.It kept causing my injectors to go bad due to excessive fuel pressure.My plans were to go with the smarty....but as I was reading it said this product design is for un-modified apps.So if I install it am I going to have the same problems??
04.5cumminsman is offline
post #2 of 13 (permalink) Old 03-08-2009, 04:44 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
I don't think so. Everyone I hear loves the Smarty. If you removed the Banks, then you should be in the clear. I've never heard of this problem before though on any tuner?
Logan
Do Or Die Garage Experiment
cummins power is offline
The Following User Says Thank You to cummins power For this addition to TDG:
04.5cumminsman (03-08-2009)
post #3 of 13 (permalink) Old 03-08-2009, 09:29 PM Thread Starter
So you think Ill be okay with the smarty?I hope so because with the banks 6 gun over a 2 year period I replaced 4 injectors at around $600.00 a piece not including labor.Thanks for the info.
post #4 of 13 (permalink) Old 03-08-2009, 10:03 PM
Hot Rod Farm Boy
I turned 21
I'm pretty sure. The whole situation sounds a little weird, I'd post up in the regular Common Rail section but I've never heard any issues with Smarty's.
Logan
post #5 of 13 (permalink) Old 03-08-2009, 11:03 PM Thread Starter
Thanks alot,not alot of DODGE people where I live mostley FORD..
post #6 of 13 (permalink) Old 03-31-2009, 02:24 AM
If your losing that many injectors I would guess that you have a filtration problem, if I were you I'd invest in an airdog or a fass, these common rail injectors don't handle dirty fuel very well, the 10micron stock filters don't do a good enough job. You will like the Smarty better than the Backs anyway, but I don't think that was your problem. I have ran a pressure box on mine for years without any problems, and I have a capped rail so I know my pressures get up there sometimes.
twhetten is offline
The Following User Says Thank You to twhetten For this addition to TDG:
04.5cumminsman (05-24-2009)
post #7 of 13 (permalink) Old 04-02-2009, 03:04 AM
twhetten that is a sweet looking truck.
95 goat, 4x4, 5 speed, long bed, big clutch, tweeked pump, 4gsk, 370's, a good turbo, lazer cut dvs, twin 6 inch turn out stacks, gauges, BHAF, 353,000 miles still running strong
New Truck: 03 goat,4x4, 6 speed, long bed, blacked out windows, bhaf....smarty soon I hope
GOAT is offline
post #8 of 13 (permalink) Old 04-04-2009, 01:48 AM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
If your putting anymore power through the motor you will need the fuel and air to support it. My stock pump only lasted 63k, about 58k or so was with some sort of programmer. If I was you, just so the truck doesn't leave you stranded with the stock stuff, add an Air Dog or FASS pump along with the Smarty Sr. I run the Smarty Sr on level 1 (fuel saver) and love the throttle response and added fuel mileage. Truck runs awesome now! Can't wait to get a tranny in it so I can see what the Smarty is really capable of.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
The Following User Says Thank You to patriot2500 For this addition to TDG:
post #9 of 13 (permalink) Old 05-25-2009, 03:55 PM
firemanram's Avatar
Good info guys. I'm looking to switch from my banks w/pda to a smarty or smarty jr. I can't make my mind up. I don't want to make a 2nd mistake!
2004.5 Dodge 4x4 Dually, Str8 piped,Smarty, HTS trans, 19.5's w/ Hankooks, Amsoil air filter in modified air intake, 32.5 5th wheel Rv
IAFF Local 706
firemanram is offline
post #10 of 13 (permalink) Old 05-26-2009, 03:21 AM
smokinsmarty06's Avatar
Images: 3
smarty not the jr. you have the trans for it i promise you won't regret it.
06 2500 6" lift 2.5" spacers,fass 150, htt turbo, 90hp inj.,IImodded cp3, SMARTY,5" straight turbo back exhaust,quad boost fooler, GOEREND full billet, ats billet flex plate,autometer pillar gauges,big line kit, capped rail,II dual feed fuel line, 37" toyo mt's, 20" moto's, s&b intake.ALL BUILT AT SOUTHERN DIESEL LAKELAND,FL
smokinsmarty06 is offline
