Looking at CRs..want helpful info on upgrades - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sexytrkr, this thread has received 12 replies and been viewed 1981 times.
post #1 of 13 (permalink) Old 04-13-2009, 01:35 PM Thread Starter
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
ok, i posted this on the regular CR forum, and didnt really get alot of responses. I didnt look down the page further till now and saw the performance section
Looking at getting another dodge. 05-07 with the 5.9 and a 6spd. crew cab dually 4x4. Im buying it to pull campers (somehow people are still buying them) so towing heavier loads will be the major factor in all this...
question is....what are some good solid mods I can do for say under 1k..First obviously are gauges, intake and exhaust. I know what gauges and exhaust i want. Not sure about the intake part. Ive been reading alot through the forum and everyone seems to like it so i plan on running the smarty. other things i plan on getting are
DD clutch
FASS 150gph
DIY CP3 kit
ANY info is helpful. I did alot of research before buying things for my stroker and the results (as the dyno numbers show) are pretty good I think.'
Thanks everyone
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #2 of 13 (permalink) Old 04-14-2009, 01:06 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Well you got an awesome start with your first mods. This would be my order.
1. Gauges
2. Exhaust
3. Intake
4. Bully dog, Edge, or Smarty
5. Then save a little cash for a clutch but if you drive it with care you will be ok for a bit.
6. Fuel System
7. Then the list could go on and on......
This should give you a good start. Hope this helps
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 13 (permalink) Old 04-16-2009, 04:34 AM
strokethisfordboy09's Avatar
tranny!!!!!
04 305 common rail, egt,boost,tranny gauges,built hts tranny with maghitech pan ,airdog150,smarty tnt,ts mp8,airaid intake,4in. staright pipe 6in. tip,jensen flip out touch screen, limo tint,4in. lift on 20 in. crome rockstars with 35x12.50x20 toyo open country mt brand spankin new
RIDIN' DIRTY MEMBER #49
Singles Club MEMBER #240
strokethisfordboy09 is offline
post #4 of 13 (permalink) Old 04-16-2009, 11:20 AM
Voice of Unreason
Eviltanker's Avatar
Send a message via Yahoo to Eviltanker
I run an 05' SRW 6spd. pulling a 33' fith wheel(8800 lbs.) I run a Quadzilla M3 Banks intake and a Volant cold air intake. Working on the exhaust yet. Pulled from Pa to Fla. no problems. EGT's stayed low even through the mountains in PA and VA. Fuel economy was pretty good also with all things considered. I think if I do it again I will go with the Smarty though.
2005 2500, Thunder Road,Smarty jr.,ATS,Volant,Firestone,BD-Power,MBRP, Rolling on 35x12.5x17's
OEF Vet 2002-2003 / 2007-2008
OIF Vet 2005/2006
Back in the Desert again 2012-?
Only the dead know the end of War.
Eviltanker is offline
post #5 of 13 (permalink) Old 04-16-2009, 12:28 PM Thread Starter
truckn'
sexytrkr's Avatar
Originally Posted by strokethisfordboy09 View Post
tranny!!!!!
even with a manual? Are they that bad?
sexytrkr is offline
post #6 of 13 (permalink) Old 04-16-2009, 01:16 PM
never owned one
post #7 of 13 (permalink) Old 04-16-2009, 04:17 PM
You will be just fine on the manual. I pushed 400 horse on my 01 and never had a problem, and there are people that pushed way more than that. Just do the cluth and you'll be fine.
01 Qc Cummins 4x4 long box, edge attitude with juice (HOT!!), 4" exhaust, afe stage 2 intake, HTB2 62/12, banks intake pleum, bully dog big fuel kit, stage three jammers, southbend 3250 DD, BD Blow off valve. PDR master and slave cylinder upgrade. Sold
2006 mega cab 4x4 auto. Stock for now.
bad_cummins is offline
post #8 of 13 (permalink) Old 04-16-2009, 04:37 PM
when your ready for the clutch call southbend and tell them what you have done to your truck and what you plan on doing with it and they will set you up with the right clutch. I don't think you will need a dd but could be wrong.
01quadcab is offline
post #9 of 13 (permalink) Old 04-17-2009, 12:54 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
I would go just like sootbandit said, pretty much word for word. You could run the Smarty on level one or two and be fine with it. The tranny will be fine, I recently found out the NV4500 is rated for 430 ft/lbs of torque, and I know the NV5600 and G56 are both higher but I don't remember what. A heavier duty single disk clutch will do fine, look at what I'm forcing through mine. I towed a 75 Chevy 3/4 ton on a trailer over the continental divide with it anyway. And it will be more street friendly than a dual disk unless you plan on doing more than you listed.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #10 of 13 (permalink) Old 04-17-2009, 01:45 AM Thread Starter
truckn'
sexytrkr's Avatar
well, i dont "plan" on doing more till i find something thats "a good deal".
Id rather spend the extra little cash for a clutch that'll take whatever id throw at it as opposed to paying for a smaller one then having to buy a bigger one. A DD cant have much more clutch pressure then the semis ive driven.
sexytrkr is offline
Helpful pics "THE DEMIZE" 7.3L Sticky Archive 0 12-26-2008 02:02 PM
Found this very helpful Bender870 Diesel Conversion 0 04-09-2008 09:26 PM
04 Help (upgrades) CBSuperduty 5.9L Cummins (2003-2007.5) 5 03-22-2006 09:35 PM
Helpful hint partsguy662 The Parking Lot 3 05-29-2005 02:54 PM
