Who Do I Talk to for Pistons - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bone stock 99, this thread has received 8 replies and been viewed 1633 times.
post #1 of 9 (permalink) Old 05-26-2009, 04:04 AM Thread Starter
I had a little mishap with my 04 dodge the other day and well cylinder #4 took the exhaust valves out. Who would be the best vendor to talk to on finding a set of pistons, Since their coming out should I go with arias or mahle performance pistons or are they way more expensive than stock?
Bone stock 99 is offline
post #2 of 9 (permalink) Old 05-26-2009, 10:46 AM
unless it's a dedicated race truck, there's no need for those piston. You'll need stock Cummins pistons which you can find at a Cummins dealer and not a aftermarket place.
triton is offline
post #3 of 9 (permalink) Old 05-27-2009, 01:46 AM
You could try the vendors section.
Jeff at http://www.mumaudiesel.com/ should be able to get you about any Cummins part you want. I recommend him.
I second the vote to stick with stock.
Dual K20s is offline
post #4 of 9 (permalink) Old 05-27-2009, 05:10 PM Thread Starter
Im gonna go ahead and stay stock on pistons but I am gonna have everything balanced. Also im gonna do a cam and stiffer valve springs cuz I dont want this to happen again. If I had a camera Id show you the aftermath. One way or another I'll find a way to post pics. Once I got the exhaust manifold off it was apparent that #4 was the cause of my shaking sputtering and smoking cuz the guides been goin bad for a while. Time to do it up right.
post #5 of 9 (permalink) Old 05-28-2009, 09:36 PM Thread Starter
Im not sure who I talked to over at mumaudiesel but that was a real chat we had and the parts arent as high as I found at other places. Im gonna build my trans myself so mumau diesel will be gettin some business once I find out where Im at on bore and bearings, depending on having to do any real big machine work. Thanks Dual K20
post #6 of 9 (permalink) Old 06-03-2009, 09:08 PM
Inline Junky!
Sledpuller500's Avatar
Images: 121
Let us know how you make out! Cummins offers a .020 and .040 piston for that motors. When mine went i had to bore .035 over to clean the cyl so i ended up putting .040 cummins pistons in. But not before i shipped them to shied for fly cutting coating and balancing
Sledpuller500 is offline
post #7 of 9 (permalink) Old 06-04-2009, 03:41 AM Thread Starter
How much was the fly cutting and balancing? Im not planning on goin too wild with it. Im definately gonna do a set of total sealed rings, I dont know if im gonna get away with just honing it or not, but I'll keep you up to date.
post #8 of 9 (permalink) Old 06-12-2009, 01:23 AM
Mahle pistons are nice. And Factory replacement in some applications.
cbtoyz is offline
post #9 of 9 (permalink) Old 06-22-2009, 02:09 AM
BigBadDodge
BigBadDodge's Avatar
Probably Jeff, he is the man and can hook up the right way
BBD
Additional Team Members
Fluidampr.com
SouthBendClutch.com
Ponci's Diesel Center
Northwesternservice.com
Reality Custom Painting
WoodruffDiesel.com
Watson Performance Engineering
AirDog
BigBadDodge is offline
New set of 6.2 pistons techteacher Whats Been Sold 0 03-29-2009 05:14 PM
Mahle Pistons BlowinSmoke 5.9L Cummins (Pre 1994) 3 03-23-2009 04:13 PM
Overhaul w/ HO Pistons? Smokem 5.9L Cummins (1998.5-2002) 5 06-10-2007 05:00 AM
powerstroke pistons in an idi troyerdiesel 7.3L and 6.9 IDI (Pre 1994) 2 10-03-2006 04:30 PM
370 Marine Pistons imported_Smokem 5.9L Cummins 12 Valve (1994-1998.5) 24 04-08-2006 12:50 AM
