tranny! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker-Smoker!, this thread has received 8 replies and been viewed 1160 times.
post #1 of 9 (permalink) Old 09-28-2009, 05:52 AM Thread Starter
tranny!
i cant keep a tranny together! i got about 900 at the wheels now and dosent matter whats in it or how builds it i need to figure out something that will work it a re 48 in a 2005 dodge. so anyone throw some ideas out there. theres talk of a stick but that dosent do good for the strip thats what the truck is for but i needs to be street alittle you know what i mean.
Stroker-Smoker! is offline
post #2 of 9 (permalink) Old 09-28-2009, 04:55 PM
900 is pretty good. What are you losing on the tranny? Shafts, clutch packs, all of the above? Also, who's stuff are you running, shafts, flex plate, clutches, valvebody etc...
post #3 of 9 (permalink) Old 09-29-2009, 12:02 AM Thread Starter
ats shafts suncoast clutchs ats vavle body but im lossinf the clutchs all the time last time industrial injection had it rebuilt. but 900 is like with alomost 0 tunning its building over a 1000 onfuel only. but it seems to me that it dosent matter who builds it. it still dosent last on hold up
thanks chris
post #4 of 9 (permalink) Old 09-29-2009, 12:18 AM
WHOS NEXT
Where are you located. I would swear by an east coast diesel tranny. He does his own clutch count and makes his own valve bodies. I have never felt an after market tranny shift like this one.
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #5 of 9 (permalink) Old 09-29-2009, 12:57 PM
firemanram's Avatar
You need to call (877) 630-9122 Dusty Hawk at HTS, his will hold up.
2004.5 Dodge 4x4 Dually, Str8 piped,Smarty, HTS trans, 19.5's w/ Hankooks, Amsoil air filter in modified air intake, 32.5 5th wheel Rv
IAFF Local 706
firemanram is offline
post #6 of 9 (permalink) Old 09-29-2009, 01:15 PM
PhilipR's Avatar
I'm a Goerend guy but HTS, Suncoast and NADP seem to be the names I seen most in racing transmissions.
-Phil-
PhilipR is offline
post #7 of 9 (permalink) Old 09-29-2009, 03:34 PM
I was going to say give HTS a shout, a friend of mine is putting down around 900hp in his 05 and racing it. Running mid 10's all day long. His clutches seem to hold up pretty well, he just has problems twisting and breaking shafts. I think you will find that a lot of guys pushing those kinds of numbers and using their stuff that hard have it go back in there a lot to fix things.
Which clutches do you seem to be losing? Are you running the stock front drum or an oversized billet drum? I know Suncoast and HTS use Alto clutches Kolene steels. Have you tried running anybody else's? DTT uses Raybestos components, and I'm not sure about the other guys. What are your clutch counts, and what is your line pressure?
post #8 of 9 (permalink) Old 09-29-2009, 04:50 PM
PhilipR's Avatar
Nothing worn with Alto or Raybestos clutches...I have used both from drag cars and trucks with no issues. The biggest thing is getting enough clutches in the drum to get the surface area and th eline pressure for them to hold....once they slip they get glazed and kiss them goodbye.
-Phil-
PhilipR is offline
post #9 of 9 (permalink) Old 09-29-2009, 11:56 PM Thread Starter
you guys seem custom is the way to go ill give those guys a call in the mornig and all the clutchs are going they like to weld them selfs together!
Tranny help 8yourv8 General Ford Truck and Excursion 2 06-18-2009 02:26 PM
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
01 needs a tranny hunterzack90 5.9L Cummins (1998.5-2002) 9 03-28-2008 12:20 PM
ZF6 tranny Kasprzak85 1994-2003 7.3L Power Stroke 3 02-10-2008 06:32 AM
New Tranny Mod!!!!!!!!!!!!!!! NMU98 2003-2007 6.0L Power Stroke 67 03-21-2006 01:15 AM
