Replacing Clutch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokin24valve, this thread has received 4 replies and been viewed 1250 times.
post #1 of 5 (permalink) Old 10-11-2009, 03:51 AM Thread Starter
WHOS NEXT
Replacing Clutch
just wanted to ask a quick question. my buddy has a 04.5 that we are going to replace the clutch in soon. he got a south bend single disk. i was wondering if there is anything special that he have to do when installing it since its a heavy duty clutch or does it just go in the same as a stock replacement. thanks for the help. and yes we are gonna get the flywheel cut.
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #2 of 5 (permalink) Old 10-13-2009, 03:57 AM
cowboytw13's Avatar
If he's running just a stock size 12 1/4", he should be fine. But if he's getting a heavy duty 13", he's gonna need a different flywheel to match up to the boltholes for the larger pressure plate.
cowboytw13 is offline
post #3 of 5 (permalink) Old 10-28-2009, 01:21 AM
bullhauler89's Avatar
I take it your going to put on a ofe have one in my 04.5 bolts right up turn the flywheel put in the pilot bearing bolt her up and good to go... read the technical sheet with the clutch, it will chatter ind sound like a injector knock, is normal but annoying.
2007 pete 379 exhd flattop single turbo bxs with some go fast parts
bullhauler89 is offline
post #4 of 5 (permalink) Old 10-30-2009, 01:16 AM Thread Starter
WHOS NEXT
Ok now you have me a little confused. What is ofe. And why does it give the sound of an injector knock.
My truck:
.093 fuel lines
Air Dog 165
custom ground cam
8 x 11 injectors
Pro 52
Polydyn header
4.10 gears
klienn train horns
603hp 1157tq
post #5 of 5 (permalink) Old 11-01-2009, 12:54 AM
ofe is south bends single disc one side organic one organic/ceramic side, chatter comes from the upgraded spings in the hub, pretty good clutch will hold 450hp on my truck
Upgraded Clutch Fork w/South Bend Clutch??? Stinger23 1994-2003 7.3L Power Stroke 5 09-07-2010 10:50 PM
Replacing clutch and flywheel ??? R33615 1994-2003 7.3L Power Stroke 3 08-06-2009 02:22 PM
Replacing the A/C Clutch.. Zaairman 1994-2003 7.3L Power Stroke 0 02-23-2008 09:23 PM
Replacing a VP44 akapparos Dodge - Modification instructions, Product installs and Tech Articles 4 08-05-2007 04:08 AM
Replacing THe TC Drrm80 1994-2003 7.3L Power Stroke 2 11-27-2006 02:34 AM
