reduceing drive pressure in my compounds? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker-Smoker!, this thread has received 5 replies and been viewed 1816 times.
post #1 of 6 (permalink) Old 11-11-2009, 08:03 PM Thread Starter
ok so im looking to figure out how to reduce the back presure in my turbos there the industrial race twins....
ive herad that if you waste gate or blow off valve helps how dose it work and what should i really do..
Stroker-Smoker! is offline
post #2 of 6 (permalink) Old 11-12-2009, 04:07 AM
SSpeeDEMONSS's Avatar
an external gate on either or both chargers would help.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 6 (permalink) Old 11-12-2009, 02:25 PM Thread Starter
who do you think would make a good setup?
post #4 of 6 (permalink) Old 11-15-2009, 09:52 PM
If you are having trouble with drive pressure, chances are you are driving your secondary too hard. Try setting the WG on your secondary to open sooner so it will drive your primary a little harder. I have mine set at 22 to 25 lbs. But keep in mind it may make it a little slower to spool.
cbtoyz is offline
post #5 of 6 (permalink) Old 11-17-2009, 05:23 AM Thread Starter
thanks just want to get everything out of it !
post #6 of 6 (permalink) Old 11-17-2009, 02:58 PM
TURBOLVR's Avatar
98.5 CSTD QCSB 4x4
Whipple/Turbonetics chargers,
7x12 stix, .093 lines & tubes
built P-pump,
TUNNELRAM 24-P intake plate,
HBX IC,
PDI T4 3-pc.
O-rings w/mild port&polish
ARP studs
H2 cam
HD pushrods/springs
NE Performance Billet auto,
custom intake horn, grid delete,
electric fans,
leveled by HELL BENT STEEL,
Thuren trac bar,
DSS braced,
RUK control arms,
custom traction bars,
5" duals.
TURBOLVR is offline
drive pressure kc04 5.9L Cummins 12 Valve (1994-1998.5) 73 07-24-2009 10:26 PM
Making a Drive Pressure setup cummins power Supporting Vendors Forum 4 07-21-2009 10:02 PM
How to keep drive pressure line from plugging cummins power 5.9L Cummins 12 Valve (1994-1998.5) 1 07-10-2009 04:59 AM
Pics of Drive Pressure gauge install. midnight2004 2003-2007 6.0L Power Stroke 11 03-19-2009 06:35 PM
Drive like Granny=OK, Drive like Earnhardt=stalls at idle GeneralLeo 1994-2003 7.3L Power Stroke 3 09-15-2006 03:39 AM
