Difference 12,24 and Cr - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MOPSD250, this thread has received 6 replies and been viewed 2626 times.
post #1 of 7 (permalink) Old 01-29-2010, 12:52 AM Thread Starter
Pappy
MOPSD250's Avatar
What is the difference in these besides the obvious valve count. What is so different about the CR? It isn;t a cummins? I'm looking to do a swap and wanna know what difference is
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #2 of 7 (permalink) Old 02-06-2010, 05:45 AM
TDG Mafia - Booze Runner
Snowaholic's Avatar
The CR is feed Fuel by a single "Common Rail" and not 6 individual fuel lines...
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
The Following User Says Thank You to Snowaholic For this addition to TDG:
MOPSD250 (02-08-2010)
post #3 of 7 (permalink) Old 02-06-2010, 10:37 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
First Generation 1989-1993 12 valve: Mechanical injection VE rotary pump, non-intercooled from 89-91, intercooled in 91.5-93, H1C turbo with a 18.5cm housing
Second Generation 1994-1998 12 valve: Mechanical injection P7100 inline pump, 94 had a WH1C turbo with a 12cm wastegated housing, later years had the HX35 turbo.
Second Generation 1998.5-2002 24 valve: electronic controlled VP44 rotary injection pump, still a pump line nozzle system, all manual trans pickups used the HX35 turbo but the 2001-2002 autos had the HY35 with a 9cm housing for emissions.
Third Generation 2003-2007 24 valve: CP3 Common Rail Injection. All the pump does is create pressure, solenoids in the injectors determine fuel delivery. 2003-2004 used the HE341 turbo with a 54mm compressor and 9cm housing, 2004.5-2007 used the HE351cw turbo with a 60mm compressor and 9cm housing.
Logan
Do Or Die Garage Experiment
cummins power is offline
The Following User Says Thank You to cummins power For this addition to TDG:
post #4 of 7 (permalink) Old 02-11-2010, 12:26 AM
I'm doing the swap also. I just bought a 12 valve really cheap. am I better off selling it and doing a common rail conversion. it will be going into a 2004 ford F-250 with a 6.0. i'm not looking to make big horse power but would like to be comparable with the 6.0 liter power and drivability. approx 400 to 500 rwhp.
2004 Black over Orange F-250. C/C 304 MBRP turbo back exaust. powertrap air filter(by Wix/Visteon).
SLAPS (St. Louis Area Powestrokes) Member.:Thumbup:
$trokin60 is offline
post #5 of 7 (permalink) Old 02-11-2010, 01:01 AM Thread Starter
Pappy
MOPSD250's Avatar
From what I have been reading a 12v is the easiest
MOPSD250 is offline
post #6 of 7 (permalink) Old 02-11-2010, 01:02 AM
********* and Mafia #90
Bcarriveau's Avatar
yes it is, 3 wires and the motor runs
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #7 of 7 (permalink) Old 02-11-2010, 03:50 AM
Go with the 12V it will be easyer and simpler. Take the time to install head studs and O rings before you install the engine. Tab the Killer Dowel Pin, and if you want 400 to 500 hp to be streetable you may as well plan on twins to keep the smoke down. You can make plenty of power with a big single turbo but it will be laggie and smokey.
openrange is offline
Difference between 6-cyl and 6-cyl H.O. 06'Duramax 5.9L Cummins (2003-2007.5) 10 10-23-2012 04:27 PM
What is the difference between... Extended Power 2003-2007 6.0L Power Stroke 1 03-24-2009 02:05 PM
Any difference? dangerous196 5.9L Cummins (2003-2007.5) 0 03-23-2008 05:58 PM
07 to 06 6.0l difference jdydiesel 2003-2007 6.0L Power Stroke 76 12-13-2007 04:15 PM
What's the Difference? diesel_girl10 The Parking Lot 2 05-15-2006 02:56 AM
