Pushrods and springs??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 10 replies and been viewed 3243 times.
post #1 of 11 (permalink) Old 03-31-2010, 05:07 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
So i need some insight on wat exactlly these will do/help me wit my truck or is it a waste? Im tuned and all emissions are gone will be adding a fuel system and head studs to it before these parts would go in.
Oh they are 110lb springs from hamilton
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 11 (permalink) Old 03-31-2010, 06:11 PM
BUCK2's Avatar
I bought factory push rods, they are really good unless you are sled pulling and running 4k+ RPM's all the time. I am also installing the 60lb valve springs.
do you need the 110's from Hamilton? If so, you also need the upgraded reatiners and keepers as well.
What are your plans for the truck?
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #3 of 11 (permalink) Old 03-31-2010, 06:31 PM
PhilipR's Avatar
I'd just get all the valvetrain stuff from the same place like Hamilton......
-Phil-
PhilipR is offline
post #4 of 11 (permalink) Old 03-31-2010, 07:56 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Here is the springs
http://www.rollinsmokediesel.com/pd-...t-pressure.cfm
Here are the push rods
http://www.rollinsmokediesel.com/pd-...-push-rods.cfm
the truck could have future pulling so i was just wondering if the springs mean i get a higher rev limiter witout floating the valves or are they going to gain me nothing...
post #5 of 11 (permalink) Old 03-31-2010, 09:02 PM
SSpeeDEMONSS's Avatar
the truck doesnt need upgraded retainers and keepers to run 110s.
i believe the springs are to help valve float and the push rods just help with the heavier springs.
if it fits in the budget do it. i did a set on a common rail and they arent that bad.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #6 of 11 (permalink) Old 03-31-2010, 09:18 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
So basically i will be able to fuel past my current red line where the fuel stops???? Im confused on if it will help any
post #7 of 11 (permalink) Old 03-31-2010, 10:17 PM
the springs will help with valve float. i dont know how high tuning can spin yours.
post #8 of 11 (permalink) Old 03-31-2010, 10:20 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
i dont think i have ever floated the valves that i could hear i just know the dyno guy told me to go from 1500rpm and gave me the kill sign around 3100-3200rpm.
post #9 of 11 (permalink) Old 03-31-2010, 10:27 PM
how high do you take it on the street? i know the heavier springs can help with higher boost so that the valves dont get blown open.
post #10 of 11 (permalink) Old 03-31-2010, 10:52 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
i usually never take it over 3000k kinda scared chit will scatter
F/S xcode front springs and pro comp rear 4.5" lift springs 6slow Whats Been Sold 4 04-26-2009 03:37 AM
2 case of bent pushrods, both using Amsoil, oil analysis Goolsbymd 2008-2010 6.4L Power Stroke 14 01-12-2009 10:35 PM
bent pushrods mrmcgoo 6.5L Diesel Engine 4 01-09-2009 01:37 AM
why are my pushrods bent? ouch! HELP!!! mad2smile 5.9L Cummins (Pre 1994) 12 01-18-2008 01:50 AM
Coil springs and leaf springs Gonzo1 5.9L Cummins (1998.5-2002) 5 04-22-2007 07:14 PM
