dsp5 switch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 516rider, this thread has received 8 replies and been viewed 1746 times.
post #1 of 9 (permalink) Old 07-09-2010, 03:48 AM Thread Starter
516rider's Avatar
Images: 3
dsp5 switch
does anyone know of a company that makes a dsp5 switch with metal threads. i keep stripping my threads and im tired of buying a new one.
2004 chevy 2500 duramax lly. no cat or anything resignator capped pcv rerouted, ats stage 3 internals with transgo shift kit, isspro ev2 gauges, custom 4 inch straight pipe with 6 inch tip, afe intake, efi live tunning, fass 150, moded cp3, injectors opened 45%, 64mm cheetah turbo soon to be replaced with twins
516rider is offline
post #2 of 9 (permalink) Old 07-09-2010, 12:17 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
Killerbee makes a metal dsp5 that uses a key instead of a knob
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 9 (permalink) Old 07-09-2010, 03:38 PM Thread Starter
516rider's Avatar
Images: 3
ok now is the key switch for a 5 position tune or is it just for 2
516rider is offline
post #4 of 9 (permalink) Old 07-09-2010, 06:34 PM
Pardue the Traveler
New 0mega's Avatar
He's got both, dsp2 and dsp5 key switches
Singles Club member #250
New 0mega is offline
post #5 of 9 (permalink) Old 07-12-2010, 02:42 AM Thread Starter
516rider's Avatar
Images: 3
ok i checked them out. i saw the key switch but is that the switch to change tunes or is that a kill switch and then it comes with a normal switch?
516rider is offline
post #6 of 9 (permalink) Old 07-12-2010, 05:41 AM
BUG JUICER and
If refering to the Keylock, it is a dsp5 switch. One position can be "kill" mode.
Michael
04.5 GMC 2500HD SRW LLY
ECM's FOR SALE
killerbee is offline
post #7 of 9 (permalink) Old 07-13-2010, 02:40 AM Thread Starter
516rider's Avatar
Images: 3
ok so if i get the key switch my tunes will stay the same. i have a stock level. so i can take the key out when its on the stock stage? also is your regular dspg5 switch have metal threads as well?
516rider is offline
post #8 of 9 (permalink) Old 07-13-2010, 03:42 AM
BUG JUICER and
correct.
The keylock is all metal. The knob switch is plastic with a higher quality switch and board that permits 2 pole/circuit control. DSP6 if you will. The 6th position (full CW) is the main tune with the 2nd circuit closed. It is meant to allow the switch to 'arm' nitrous, meth, propane, etc. The 5th position is also the main tune, with the 2nd circuit open.
Michael
ECM's FOR SALE
post #9 of 9 (permalink) Old 07-19-2010, 06:48 PM
iranaround's Avatar
can i add a valet switch without loosing any tunes
05 LLY GMC Duramax Crew Cab SLT
Two inch lift 285 BFG t/a s
Edge Evo
AEM Brute Force
PPE Duramax Race Fuel Valve
MBRP Turbo Back 4in to 8in single stack
EFI Live with dsp5 tuning by Nick
http://www.lubedealer.com/FIglar_Per...ce_Synthetics/
iranaround is offline
dsp5 switch 516rider Supporting Vendors Forum 0 07-01-2010 02:03 AM
efi tuning with dsp5 516rider Duramax 2004.5-2005(LLY) 17 01-25-2010 07:54 PM
Anybody know what this switch does? Beer Mod 1994-2003 7.3L Power Stroke 7 01-26-2008 03:25 PM
EFILive DSP5, 5 Position Tune Flashscan LLY Tuner Forum 6 02-28-2007 10:36 AM
EFILive DSP5, 5 Position Tune Flashscan LB7 Tuner Forum 0 10-24-2006 10:52 AM
