Dynoed my truck and another truck I tune - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bobo, this thread has received 25 replies and been viewed 3210 times.
Closed Thread
post #1 of 26 (permalink) Old 04-04-2006, 04:30 AM Thread Starter
Tire Smoker
bobo's Avatar
Send a message via AIM to bobo Send a message via Yahoo to bobo
Here are the results. A Kennedy LLY Race tune was used for comparison on my truck. We switched to Matt's truck and I loaded a tune I made for truck pulling(EGT's are very controlled). Completely stock motor on #2 only. Here are the results:
ID:	4644   Click image for larger version
ID:	4645   Click image for larger version
Name:	bobvskennedy tq and hp.jpg
ID:	4646   Click image for larger version
Bobo's Truck Website
Special Thanks to: Huckstorf Diesel, Merchant Automotive, EFILive, Mike L. @ Inglewood Transmission
05 Twin Turbo Duramax
[email protected]+ on #2 only
bobo is offline
post #2 of 26 (permalink) Old 04-04-2006, 04:40 AM
Rich's Avatar
Why does John have that awful *swack* in his curve?
Rich is offline
post #3 of 26 (permalink) Old 04-04-2006, 04:52 AM Thread Starter
Tire Smoker
bobo's Avatar
I know, but I'll let him figure it out. It is easy to fix, but Kennedy needs to fix it. I could tell right away what it was doing. His tune is fun to drive.
bobo is offline
post #4 of 26 (permalink) Old 04-04-2006, 01:46 PM
And quick isn't it?
I can put more smoke into it and bring it up, but the present tune is designed to be driveable street and race without too much excessive smoke. It's also been tuned with a load which is why it excels under "road load" conditions.
Kennedy Diesel is offline
post #5 of 26 (permalink) Old 04-04-2006, 02:32 PM
Loves Jet Noise
NoWake200's Avatar
Send a message via Yahoo to NoWake200
When you say Kennedy Race Tune, is this a program you came up with Kennedy? Also what kind of trans work was done if any?
I do like that 120mph+,all that torque, and HP....ok I like everything.
TWA
2011 F-350 Lariat, 6.7 PowerStroke, Crew Cab, Short Bed, White with 20" Wheels.
NoWake200 is offline
post #6 of 26 (permalink) Old 04-04-2006, 06:59 PM
This is a version of my LLY Race tune as plotted on my web site. I call it a "race" tune, because of the power output, but it is mild mannered enough to tow and drive daily IF you are careful. For full strip use, I may need to get a bit more aggressive. As is, it ran 13.5 at 100mph on Brandon's wife's LLY.
You WILL need a built transmission for this tune. The unit tested was RaceHemi's and is speed limited at 120mph.
http://www.kennedydiesel.com/photoga..._Race_Tune.jpg
post #7 of 26 (permalink) Old 04-04-2006, 07:44 PM Thread Starter
Tire Smoker
bobo's Avatar
I'm going to the track tonight. The Kennedy tune is a fun tune to drive, but not as fun as mine....mostly because it is mine and I love it. I'm not pulling any weight out at the track today. 6970# and we'll se what it will do. Should be a good time. I'll post results ASAP. It is a beautiful day, but kinda windy. I can't wait to race. There might be a Kennedy tune for me to race!
bobo is offline
post #8 of 26 (permalink) Old 04-04-2006, 07:50 PM
6070?????
A EC/SB is 6400lb, and even 2wd is 6150 IIRC.
Are the tires filled with helium?
McRat is offline
post #9 of 26 (permalink) Old 04-05-2006, 05:07 AM Thread Starter
Tire Smoker
bobo's Avatar
best tonight was:
RT: .074
60': 1.868
330: 5.564
1/8: 8.624
MPH: 80.42
1000: 11.273
1/4: 13.522
MPH: 100.31
I backed it up with 4 other drivers!
Matt had about the same numbers. Track conditions sucked! Could only launch at 5-6 psi and spun real bad. This was at 6970# and stock TCM tuning. It is only going to get better. Had a blast. Thanks to everyone that showed!
Huge thanks to Merchant, Huckstorf, EFI, and my Alienator trans!! The more I beat on it, the better it shifted. Very consistent!
bobo is offline
post #10 of 26 (permalink) Old 04-05-2006, 05:21 AM
Rich's Avatar
Cool, great effort! :Thumbup:
..those times did look a little slow. I figured in the 1/8 you'd be in the 8.36 range. Dang, no such luck.....:crazy:
Rich is offline
Closed Thread
