LLY question for you perf guys - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Deerhunter, this thread has received 6 replies and been viewed 1188 times.
post #1 of 7 (permalink) Old 08-12-2006, 02:18 PM Thread Starter
Cool site.
I have a 04.5 lly crew cab 4wd with 40k on it. I have recently installed the Edge Easy program and like it.
I was wondering what other minor upgrades you guys might suggest.
Not looking to break the bank just looking for the simple but effective mods that you guys probably have found thru the years.
tires are 265 Michelin X Radials
K&N filter
thanks, Gary
Deerhunter is offline
post #2 of 7 (permalink) Old 08-13-2006, 03:04 AM
Probably add a PPE boost controller to give more power and adjust boost to where you like it.
McRat is offline
post #3 of 7 (permalink) Old 08-13-2006, 04:24 AM
Deer Hunter:
2:
If your modification considerations are improved longevity, fuel mileage and daily driving and towing performance, you may wish to consider the following.
The below is a common sequential approach to mild mods:
1. Disable EGR, reroute PCV.
2. Install 4" exhaust; cat-back is good, front pipe and cat back is better!
3. Install cold air intake; stock paper element filters best.
These mods alone are relatively easy, inexpensive and will provide improvements you can feel. To obtain even better fuel mileage and daily driving and towing performance:
4. Install Boost Stick
5. Install mild tuner; (Edge EZ is an excellent choice!)
If you tow heavy, you may wish to consider installation of gauges. Even a stock LLY can experience excessive EGTs under certain conditions!
The above mods are very mild; relative to what's available, and are easily returned to OEM if necessary.
I'm no expert and have undoubtably omitted several good ideas, but this will get you started!
- Steve
2004.5 2500HD CCSB, 4x4, D/A, tow tune, TD-EOC
Goodies occupying space in garage: Corsa full exhaust, Isspro gauges, KB CAI
2006 Tahoe Transport 33WTB; 14,000 lbs.
stevebos is offline
post #4 of 7 (permalink) Old 11-27-2006, 02:15 AM
REMEMBER!. if you put too much fuel to an LLY it'll throw a 1093 code, you will have to shim the fuel rail pressure return valve.
samfraser is offline
post #5 of 7 (permalink) Old 12-28-2006, 05:14 AM
Tire Smoker
bobo's Avatar
Send a message via AIM to bobo Send a message via Yahoo to bobo
Dont forget Boost and EGT gauges.
Bobo's Truck Website
Special Thanks to: Huckstorf Diesel, Merchant Automotive, EFILive, Mike L. @ Inglewood Transmission
05 Twin Turbo Duramax
[email protected]+ on #2 only
bobo is offline
post #6 of 7 (permalink) Old 02-28-2007, 10:35 AM
LarryJewell's Avatar
guages, intake, exhaust, efi, etc...
04' LLY
MPI Twins (71.5 Cheetah & S475)
PPE Duel Fuelers
Suncoast Stage III
LarryJewell is offline
post #7 of 7 (permalink) Old 05-29-2007, 02:52 AM
Gauges are a must!
Swenson24 is offline
Closed Thread
