need LLY advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by farmer, this thread has received 17 replies and been viewed 1827 times.
Closed Thread
post #1 of 18 (permalink) Old 11-26-2006, 02:15 PM Thread Starter
need LLY advice
Hi guys, im a newcomer here and somewhat of a greenhorn in the diesel pickup seen. Im looking for someone who's had experience with the intimidator chip.My truck is an'05 with stock 245 75R16 but am thinking of switching to 265's. Will this affect my performance in anyway?
farmer is offline
post #2 of 18 (permalink) Old 11-26-2006, 05:24 PM
Mafia Member
mother_goose's Avatar
Im a lil hungover right now and my brain isnt functioning. Who makes the intimidator chip? Performance wise you should not see a really noticeable difference you are only going from 245s to 265s. Is it a tuner or a plug in device? Most tuners you can put in tires size.
mother_goose is offline
post #3 of 18 (permalink) Old 11-26-2006, 05:40 PM
moose99psd's Avatar
as you go bigger with the same gears you will lose a little.. but with the sizes only going from 245-265 the diffrence will be minimal. you should be perfectly fine.. but like goosey said if its a programmer u might be able to put in for tire size but that usually just recalibrates ur speedo IIRC
moose99psd is offline
post #4 of 18 (permalink) Old 11-26-2006, 09:34 PM Thread Starter
thanks guys for the replies. The intimidator chip is popular up in the north east part of maine. Sold out of Bangor diesel. IT plugs in under the dash and you program the level of hp you desire and tire size etc.. then you uplug it until you need to make a different adjustment. If you go to extreme diesel.com you can get more info.
farmer is offline
post #5 of 18 (permalink) Old 11-27-2006, 01:28 AM
265's won't hurt performance at all. They only make a +2-3 mph difference at 70mph.
TheBac is offline
post #6 of 18 (permalink) Old 11-27-2006, 10:41 AM
Thats the BD initimdator. Ive never tried it before but i will say im partial to the Diablosport predator programmer myself. does the same as the intimidator but also shows realtime data.
2005 GMC 2500HD 4x4 DMax ZF-6
Blizzard 800 plow, Triple stack of doom
285 BFG mud terrains, Conrad 4" straight pipe, Dynadroit dual disc
Its a work truck
Ben46a is offline
post #7 of 18 (permalink) Old 11-27-2006, 10:14 PM Thread Starter
how about fuel mileage? will 265's improve ?
farmer is offline
post #8 of 18 (permalink) Old 11-28-2006, 12:26 AM
Maybe a little bit. You'll be turning slightly less RPMs on the road per MPH.
TheBac is offline
post #9 of 18 (permalink) Old 11-28-2006, 09:53 AM Thread Starter
why does chev insist on stock 245's? Is it because they can withstand more weight?
farmer is offline
post #10 of 18 (permalink) Old 11-28-2006, 04:22 PM
Mafia Member
Not really sure of the answer to this question. If you get a 1 ton single rear wheel it comes with 265s......so you got me. I dont think they can even asnwer that question.
Closed Thread
