PPE Lift Pump? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminskiller, this thread has received 8 replies and been viewed 1264 times.
post #1 of 9 (permalink) Old 08-20-2007, 08:23 PM Thread Starter
PPE Lift Pump?
Has anyone on here installed the PPE lift pump? Was it hard? How much time did it take? What kind of modications needs to be done? Does all the hardware u need to install it come with the pump?
cumminskiller is offline
post #2 of 9 (permalink) Old 08-21-2007, 07:08 PM
if you want to run more then 450rwhp go with a better pump but if you want something to mantain a good size programmer and thats it is does a excellent job on my 06 LBZ and no it doesn't take long and all the hardware comes with the pump..
TYREBOYZ_DMAXIN is offline
post #3 of 9 (permalink) Old 08-21-2007, 08:27 PM Thread Starter
Any troubles I should worry about running into when installing the pump? and where exactly is a good location for it?
post #4 of 9 (permalink) Old 08-22-2007, 03:52 PM
its all in the instructions but the closer to the tank the better or thats what they said and so far so good but the one thing i did change was i turned it up some,when you look on the side of the pump you will notice a screw give it a few turns clockwise..
post #5 of 9 (permalink) Old 08-22-2007, 07:18 PM Thread Starter
So all the fittings and everything you need comes with the pump right?
post #6 of 9 (permalink) Old 08-22-2007, 07:35 PM
yep its all there..if you want my true opinon go with the Kenedy pumps from http://www.kennedydiesel.com/
post #7 of 9 (permalink) Old 08-22-2007, 08:04 PM Thread Starter
what kinda pump are you running? Do you have to drop the tank to install the ppe lift pump? Is the single kennedy pump pretty good?
post #8 of 9 (permalink) Old 08-25-2007, 02:13 PM
i have the PPE lift pump on my LBZ and use to have it on my LLY and it supports the HOT ET+2 that is one my LLY but with the Van Aaken stacked it was to much for that pump and now i have the pump on my LBZ with the Hot +2 and it does a great job but any more then that it needs a bigger pump so thats the reason i say go with the kennedy twin pumps and the bigger fuel lines if you want more then 480rwhp...
post #9 of 9 (permalink) Old 08-25-2007, 02:14 PM
all these pumps are outside the tank..
Closed Thread
