What would happen? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker81, this thread has received 9 replies and been viewed 902 times.
post #1 of 10 (permalink) Old 09-10-2007, 01:26 AM Thread Starter
What would happen?
My cuz has the bullydog programmer programed in the pcm, and he got the normal edge box that is like 90 hp. Now can he stack the 2 together or is that bad. He does not have a computer, and I am no duramax guy. Would be thankful for honest answers.
Thanks
Stroker81 is offline
post #2 of 10 (permalink) Old 09-13-2007, 07:51 PM
depends on how much timing they both put together i never stacked them together it may not stack together
fwdcummins is offline
post #3 of 10 (permalink) Old 09-13-2007, 10:39 PM
i have never done it, but i have read that they do not stack well together. lots of people have stacked edge with ppe and works well. you should tell him to look into efi cheaper than bullydog and edge together. and limitless possibilities
pa_coalminer is offline
post #4 of 10 (permalink) Old 09-14-2007, 12:41 AM
I'm pretty sure that you can stack them, but you'll have to play with the levels to find a combo that works. I think you end up running the BD on highest, and the Edge on level 1 or 2.
TheBac is offline
post #5 of 10 (permalink) Old 09-14-2007, 12:43 AM
You can stack them, but have to play with the levels to find one that works. I think you end up running the BD on highest, and the Edge on level 1 or 2.
TheBac is offline
post #6 of 10 (permalink) Old 09-14-2007, 10:42 PM
what does putting the edge with the ppe get you will you be able to control the ppe with it?
bigcountry is offline
post #7 of 10 (permalink) Old 09-16-2007, 03:49 AM Thread Starter
OK thanks guys, I will let him know. I have tried to get him to get rid of that bullydog but wont do it.
post #8 of 10 (permalink) Old 09-16-2007, 06:01 PM
no you will not be able to control, but they work better as a combination together. i would guess its the ppe programming, but i dont know enough to say why it works better.
post #9 of 10 (permalink) Old 09-17-2007, 07:19 AM
Kat
I hope he has a built trans or is planning on it :Thumbup:
While they may stack. I can almost guarantee it will limp a stock trans.
Kat is offline
post #10 of 10 (permalink) Old 09-18-2007, 08:20 PM
LarryJewell's Avatar
I stacked the Bullydog with the edge for a while and also the ppe, both the standard and hot + 2. The stacks ran better having a lift pump, but the edge still didnt always act real nice. The best of the stack was the standard ppe set on kill and edge set on 5/5.
Efi is a lot nicer..........
04' LLY
MPI Twins (71.5 Cheetah & S475)
PPE Duel Fuelers
Suncoast Stage III
LarryJewell is offline
Closed Thread
