Stacking an LLY question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Unbroken, this thread has received 14 replies and been viewed 1389 times.
Closed Thread
post #1 of 15 (permalink) Old 12-17-2005, 02:27 PM Thread Starter
I have a friend that just stacked his 04.5 LLY.
He was running the Superchips tuner. Not sure the model #
Yesterday he added the Edge/Attitude to it.
Other than the tranny....which he knows he has to upgrade since his converter is already slipping....what can be expected?
Any trouble spots to look for?
It also has an AFE intake and 4" exhaust goes on Monday.
2wd CC truck...any idea on 1/4 times...assuming good traction can be had ?
Unbroken is offline
post #2 of 15 (permalink) Old 12-17-2005, 05:22 PM
11 Second Truck Club
Send a message via AIM to BMDMAX
Is he trying to stack the highest HP tune on the Superchips or one of the smaller ones? Not that it really matters since the HP won't be getting to the ground without the trans and each limp will make it progressively worse. The fuel system is going to fall on its face at that level too, minimum of lift pumps and probably a shim mod.
You will likely be in the high 14's at the highest stack level if the fuel system or trans does not punt. 13's can be had with the trans.
Stacked EGTs will be high. A boost stick will help.
2002 LB7 D/A 2WD. Suncoast Stage V. KD EFILive Tuned, KD N2O, KD 40 Over Injectors, MDP Custom Fuel System, KD MEGA Filter, BD Turbo
2005 LLY D/A 2WD. KD Headlight Booster, KD 4/5 Exhaust, Suncoast Stage V, KD EFILive Tuned.
LB7:[email protected] #2 Only [email protected] #2W/N20
LLY: 471HP & 990 TQ [email protected]
Read about Weekend on the Edge 2005
Truck Website
Chasing 11's Video
Go Fast Goodies Powered by Kennedy Diesel
11 Second 2WD Crew Posse Member!! Got Slicks?
BMDMAX is offline
post #3 of 15 (permalink) Old 12-17-2005, 06:23 PM Thread Starter
Far as I know...he plans to run both on their highest setting.
Where can I find out about the lift pumps and shim mod?
BTW...his tranny stuff is ordered....it'll be done shortly.
Unbroken is offline
post #4 of 15 (permalink) Old 12-18-2005, 09:44 PM
Tire Smoker
bobo's Avatar
Send a message via AIM to bobo Send a message via Yahoo to bobo
Don't use the Edge for stacking. It will cause problems and it will not run very good. Get a VA box to stack with.
Bobo's Truck Website
Special Thanks to: Huckstorf Diesel, Merchant Automotive, EFILive, Mike L. @ Inglewood Transmission
05 Twin Turbo Duramax
[email protected]+ on #2 only
bobo is offline
post #5 of 15 (permalink) Old 12-19-2005, 12:31 AM Thread Starter
Too late....
Unbroken is offline
post #6 of 15 (permalink) Old 12-19-2005, 01:40 AM
Tire Smoker
bobo's Avatar
Too late....
I'll be the guy laughing in the back w/ the "I told ya so" look on my face.:shrug:
Good Luck!! You will need it! Been there, done that.
bobo is offline
post #7 of 15 (permalink) Old 12-19-2005, 01:59 AM Thread Starter
Fortunatly it's not my truck.
I did'nt even know he was doing it till it was done....so I figured I'd see how good/bad it will be.
Soon as his tranny is done we're gonna line em up...his D-Max/stack vs my 6.0/SCT
Unbroken is offline
post #8 of 15 (permalink) Old 12-19-2005, 12:46 PM
Tire Smoker
bobo's Avatar
It is not his trans I am woried about. You will woop him.
bobo is offline
post #9 of 15 (permalink) Old 12-19-2005, 12:56 PM
Depends on how strong that LLY runs. With trans, fuel system mods and just the Juice on 5/5 a strong 4WD launch you should be close to 13's.
I ran a 13.8 with my 2WD LLY on just the Juice.
Truck Website
Chasing 11's Video
BMDMAX is offline
post #10 of 15 (permalink) Old 12-21-2005, 01:16 PM
Tire Smoker
bobo's Avatar
I thought you had a custom beta yada yada on it when you ran the 13.8?? That is a very good time from a 2wd!
bobo is offline
Closed Thread
