Advice on next upgrade... one step at a time - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sunburnpoptarts, this thread has received 21 replies and been viewed 6337 times.
post #1 of 22 (permalink) Old 04-24-2010, 07:29 PM Thread Starter
sunburnpoptarts's Avatar
Hello everybody,
I'm new to this form.. as a member anyways. Been reading and learning a lot from here recently. It's time for me to tap into some of the wisdom of other members.
Current stats:
05 LLY, 55k mi. 2500hd short box ext. cab
Banks Intake
Magnaflow 5" downpipe back exhaust
AFE Blade Runner Turbo Inlet
My long term goal is major horsepower (550+) in a reliable daily driver. Each upgrade I purchase, I only want to purchase once. In other words, I don't want to add an aftermarket part to add power that will again need to be upgraded. Hence the bit of overkill with a 5" exhaust and no tune (yet)
So from here... where? Fuel delivery upgrade? PPE boost controller?
I want to always have the drivetrain able to support the current power I am making. Thank you in advance for the advice folks
sunburnpoptarts is offline
post #2 of 22 (permalink) Old 04-25-2010, 10:44 AM Thread Starter
Would anyone recommend EFI Live? I figure since it's capable of pretty much any tune imagineable it would be well suited from 300-350 hp applications to much much higher.
post #3 of 22 (permalink) Old 04-26-2010, 02:29 AM
516rider's Avatar
Images: 3
efi live is the best tuner out there imo. i have it on my truck and love it. the main concern with the hp is the stock tranny i think can support 500 hp. im not 100 percent sure tho. but id go with efi. i havent heard much about the ppe boost controler
2004 chevy 2500 duramax lly. no cat or anything resignator capped pcv rerouted, ats stage 3 internals with transgo shift kit, isspro ev2 gauges, custom 4 inch straight pipe with 6 inch tip, afe intake, efi live tunning, fass 150, moded cp3, injectors opened 45%, 64mm cheetah turbo soon to be replaced with twins
516rider is offline
The Following User Says Thank You to 516rider For this addition to TDG:
sunburnpoptarts (04-26-2010)
post #4 of 22 (permalink) Old 04-26-2010, 03:02 AM
Pardue the Traveler
New 0mega's Avatar
Efi Live is worth the money if your willing to spend the time to learn it.
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
post #5 of 22 (permalink) Old 04-26-2010, 04:40 AM Thread Starter
absolutely. Got to admit it's pretty intimidating at first glance. But the fact that the possibilities are almost endless is a major draw in.
Anybody have experience with Kennedy Diesel or PPE's boost controllers that work with the stock turbo? Seems like a decent low level upgrade that won't hurt a stock drivetrain.
05 2500HD short box ext. cab LLY
T-bars cranked, 275x75R16's on stock rims
Banks Intake, Magnaflow 5" downpipe-back exhaust, AFE Blade Runner Turbo Inlet; turbo resonator plugged,
BD Power exhaust manifold, Autometer Boost and EGT Gauges
Merchant Marine. Well versed in 70,000+HP marine diesels.. still a student in 300-500HP diesels.
post #6 of 22 (permalink) Old 04-26-2010, 04:42 AM Thread Starter
I would only add 80-100hp before taking a look at transmission upgrades for sure. EFI Live seems like an awesome investment.
post #7 of 22 (permalink) Old 04-26-2010, 06:31 AM Thread Starter
Another question regarding a stock turbo boost controller. Any risk of damage from trying to get rid of all that extra boost? Say, after hard acceleration and quickly letting off the throttle, does the stock wastegate handle this type of situation?
post #8 of 22 (permalink) Old 04-27-2010, 03:09 AM
516rider's Avatar
Images: 3
well according to kennedy diesel his boost control works best with a tuner if i remember correct. i was wanting one for mine. i did a thread on that a while back. i know there was some great advice on it
516rider is offline
post #9 of 22 (permalink) Old 04-27-2010, 04:31 AM Thread Starter
Sounds good. It makes sense a tuner would supplement it. Added boost isn't going to help anything without more fuel.
post #10 of 22 (permalink) Old 04-29-2010, 12:20 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
With EFI live you can control everything the turbo can do, the LLY uses a Variable Vane Turbo, or VVT, or VGT, or VNT...... in essence, on the drive(exhaust) side of the turbo instead of a set of fixed vanes that require a set amount of exhaust pressure to drive the turbo, a VGT uses a set of variable vanes that can allow the turbo to spool on very little pressure, makes for a very little turbo lag, they also do not require a waste-gate because when the turbo is making high boost, and you let off the throttle the vanes will open allowing all the boost to flow out the exhaust instead of over speeding the turbo, it creates a loud "wooshing" sound that can be a bit off putting the first time you hear it
EFI is the end all-be-all tuning for the Duramax, i suggest downloading the program off of EFI's site and play around with it, you can down load it free without the V2 flashscan, but you cant save changes to tunes, but you can get a feel for how complicated it is with fueling tables, boost tables, injection tables etc...
a PPE or suncoast transmission would be under extreme advisement, if you add more that 80-100hp you can expect to limp your transmission in a hurry
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
sunburnpoptarts (04-29-2010)
Time to step down Rcannon Site Information 37 02-19-2008 04:32 PM
Time to Upgrade!! Blk350on20s 2003-2007 6.0L Power Stroke 34 03-15-2007 03:59 AM
Wheel Bearing 01 Ford, step by step?? imported_CWAGO General Ford Truck and Excursion 12 01-02-2007 06:32 PM
