03 LB7 Injector Replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Billu, this thread has received 5 replies and been viewed 5363 times.
post #1 of 6 (permalink) Old 01-19-2012, 01:13 PM Thread Starter
Billu's Avatar
Looking to replace injectors on a 03 LB7 - already have a Banks tuner with the exh. temp probe - which brand to you suggest? looking for hp increase and mileage.
Banks 6 Gun with the optional Speed Loader
also looking for Allison upgrade suggestions for the same dually truck
Billu is offline
post #2 of 6 (permalink) Old 01-19-2012, 06:01 PM
Pardue the Traveler
New 0mega's Avatar
The Bosch injectors should be able to handle the Banks, the stock injectors are rated for up to 500rwhp and I don't think the banks tunes past that. Trans upgrades, well a Gmax 5 pac from Suncoast with a 1053-1058 torque converter or a ATS kit. If you the kit you choose doesn't come with it don't forget to get a transgo shift kit and a transgo Jr kit as well.
Singles Club member #250
New 0mega is offline
post #3 of 6 (permalink) Old 01-19-2012, 07:21 PM Thread Starter
Billu's Avatar
is the banks kit with stock injectors too much hp for a stock trans? Will the Transgo jr kit provide any additional protection to the stock trans? I do not want to put that much work into the truck.
Billu is offline
post #4 of 6 (permalink) Old 01-20-2012, 08:16 PM
Pardue the Traveler
New 0mega's Avatar
Depends on what tune your running, anything over 100rwhp over stock is getting to the danger zone with a stock trans. the transgo and transgo Jr will help a bit, add and extra 50-75rwhp over stock.
post #5 of 6 (permalink) Old 01-27-2012, 08:50 PM Thread Starter
Billu's Avatar
Any Suggestion where to purchase the injectors from?
Billu is offline
post #6 of 6 (permalink) Old 07-24-2012, 04:27 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
Merchant automotive, I would stick with stock injectors unless you plan on going with bigger air and extra fueling, I know of a few trucks that have made 550+ hp with stock injectors
The transgo jr kit will NOT help the 5-speed Allison, there are clutch applies in the FULL transgo kit that need to be installed to make the trans hold more power, and in order to install the full kit you need to pull the trans, and if you're going to do that you may as well rebuild it with a suncoast GMax5 kit to upgrade the clutches and steels
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
Injector replacement Rodney R Medium and Heavy Duty 22 11-28-2011 11:42 PM
I need help please, about injector replacement German Frank Duramax 2001-2004 (LB7) 3 09-02-2009 11:45 PM
Injector replacement cost sundownbrown 2003-2007 6.0L Power Stroke 7 03-06-2009 12:32 AM
LLY Fuel Injector Replacement (Right) ripmf666 GM Spec Info 0 12-28-2008 11:39 AM
Need help with injector replacement on 05 CTD m3transporter 5.9L Cummins (2003-2007.5) 0 12-15-2007 02:14 AM
