PPE Boost Valve? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tahoedmax, this thread has received 8 replies and been viewed 1947 times.
post #1 of 9 (permalink) Old 02-25-2007, 04:05 AM Thread Starter
diesel idiot
PPE Boost Valve?
Do any of you guys run that PPE valve that tricks the wastegate?? Is this thing actually reliable for a 30 dollar part to give you that much more boost?? Thanks guys
2004 Chevy CC/SB LB7 LT3
EFILive, SC Trans w/ 1058 by me, Traction bars and centerlink braces built by me, Custom adjustable stock wastegate, 6 inch custom exhaust, 1792 Lift Pump, Belltech 3" drop shackles, Black H2's w/ Falken 285/60/17s for summer, BFG 315/70/17s for winter, SD sleeves, DiPricol EGT and Boost gauges on the pillar along with an Aeroforce for rail PSI and trans temp, 2 Kicker Comp CVT 10's w/ memphis amp, t-rex full face billet grille,limo tint, .Oh yeah I'm 20 and I built and tuned it myself.
tahoedmax is offline
post #2 of 9 (permalink) Old 02-25-2007, 03:41 PM
depending on the fueling, I've seen 3-5 psi increase, sometimes more....
the only thing is, if you're runnin a lot of fuel, it's pretty easy to go over the 30-32psi range, but that probably depends on the tuning.....
later, TW
6shifted is offline
post #3 of 9 (permalink) Old 02-25-2007, 05:01 PM
i have the boost valve and took it out because i get more drive pressure psi(15-20psi of boost)on the highway cruising with the 315 toyos mt tires with the valve, which really affects fuel economy and it more wear on the motor
dmaxvaz is offline
post #4 of 9 (permalink) Old 05-19-2007, 02:48 AM Thread Starter
diesel idiot
Im not running a ton of fuel so Im going to see what results I get from the valve, and if i hate it, hey it was only 27 bucks.
post #5 of 9 (permalink) Old 06-20-2007, 12:50 PM
BUG JUICER and
Just curious here. How do the tires factor in to increase drive pressure?
Michael
04.5 GMC 2500HD SRW LLY
ECM's FOR SALE
killerbee is offline
post #6 of 9 (permalink) Old 06-21-2007, 10:09 PM Thread Starter
diesel idiot
I dont know i have the ppe on mine and i havent really seen a decrease in mileage. I didnt put the valve halfway in the line though i put it closer to the wastegate because i dont want 32 psi. how would this technically cause wear on the motor? the turbo maybe if you hammer down on it for long periods of time
post #7 of 9 (permalink) Old 06-22-2007, 12:33 AM
hell if i know:shrug: , what i noticed is the boost stays up like at 15 psi on the freeway. anyways i put the valve back in.
dmaxvaz is offline
post #8 of 9 (permalink) Old 06-22-2007, 01:56 AM
BUG JUICER and
FWIW, 15 psi on the freeway, is about 14.9 psi more than can be used in combustion.
Oh wait, are you measuring absolute pressure (MAP) on a scanner? If so, 15 psi map is about 1 psi of boost.
Come to think of it, 15 psi of boost is not even possible at normal empty highway cruise, there is not enough exhaust gas to make that happen, even the VGT can't do it.
Michael
ECM's FOR SALE
post #9 of 9 (permalink) Old 07-14-2007, 05:18 AM Thread Starter
diesel idiot
Yeah i boost about 5 psi on the freeway on a line plumbed to the discharge. 15 psi on the freeway is not happening. I havent gotten any worse mileage with the PPE, and im pretty much smokeless now so i wont complain its a cheap fix.
Closed Thread
