cold air intake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01quadcab, this thread has received 16 replies and been viewed 3919 times.
Closed Thread
post #1 of 17 (permalink) Old 07-04-2007, 11:44 PM Thread Starter
cold air intake
whats the best intake out for an 01?
01quadcab is offline
post #2 of 17 (permalink) Old 07-05-2007, 05:41 AM
TDG Junior Mafia #61
Dieselson's Avatar
AEM or PPE, something that is not oiled.
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline
post #3 of 17 (permalink) Old 07-05-2007, 05:44 AM Thread Starter
that seems to be what I have heard lately.. whats with the oiled filters being so bad now? they were all the rage forever whats changed? I have a k&n on my dodge should I get a aem filter and get rid of the k&n?
post #4 of 17 (permalink) Old 07-05-2007, 09:05 PM
Dieselson's Avatar
If you over oil them accidently, they can screw up the MAP sensor and cause codes and limp mode.
TDG Mafia
The Diesel Garage
"Can you keep up??
post #5 of 17 (permalink) Old 07-05-2007, 09:32 PM
DPDIESEL's Avatar
S&B Filters air intakes work very well.
Performance Diesel Motorsports
5,500 RPM Common Rail Anyone??
DPDIESEL is offline
post #6 of 17 (permalink) Old 07-06-2007, 12:37 AM Thread Starter
ok that helps I just like to understand why things are a no if you know what I mean.. I totally appreciate everyones help and input on this especially with a duramax because I don't personally own one and don't want my neighbor having problems when I am helping him to upgrade his power etc.. by far this has been the best site I have used :thanks: :smoke
post #7 of 17 (permalink) Old 07-07-2007, 09:16 AM
diesel idiot
I agree that S&B work well. I have one on my truck and its been great i got rid of my first intake and have been very pleased with the fit, finish and filtration of this S&B. Just dont over oil your filter its not that hard.
2004 Chevy CC/SB LB7 LT3
EFILive, SC Trans w/ 1058 by me, Traction bars and centerlink braces built by me, Custom adjustable stock wastegate, 6 inch custom exhaust, 1792 Lift Pump, Belltech 3" drop shackles, Black H2's w/ Falken 285/60/17s for summer, BFG 315/70/17s for winter, SD sleeves, DiPricol EGT and Boost gauges on the pillar along with an Aeroforce for rail PSI and trans temp, 2 Kicker Comp CVT 10's w/ memphis amp, t-rex full face billet grille,limo tint, .Oh yeah I'm 20 and I built and tuned it myself.
tahoedmax is offline
post #8 of 17 (permalink) Old 07-07-2007, 01:35 PM
Honestly, the overall best intake for a stock-to-500hp application is the OEM unit.
TheBac is offline
post #9 of 17 (permalink) Old 07-07-2007, 06:36 PM
DPDIESEL's Avatar
I would have to disagree with that. It has been tested many times and air intakes do help on stock trucks.
As far as over oiling, the S & B precision oil kit helps alot in making it so you don't over oil your filter.
DPDIESEL is offline
post #10 of 17 (permalink) Old 07-07-2007, 11:06 PM Thread Starter
so if you say not to over oil an air filter then if you do that and keep oil down to the min needed then why stay away from k&n? if you say use an oiled filter why is k&n so wrong? just curious
Closed Thread
