03 Stacked chip ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dancin Dave, this thread has received 8 replies and been viewed 2408 times.
post #1 of 9 (permalink) Old 09-18-2007, 02:59 PM Thread Starter
03 Stacked chip ?
I have a 03 with a banks six gun with a 100 hp shot of nitrous. Im told the banks wont give me enough fuel for the nitrous to do me any good. Ive also been told to stack the ppe on top of the banks and that will give me enough fuel to use the nitrous. Has anyone done this? Will the PPE chip be enough to solve my problem?
Dancin Dave is offline
post #2 of 9 (permalink) Old 09-18-2007, 06:41 PM
Simply Put, Yes.....If you run a HOT+2 E.T. you will have plenty of fuel. there wont be any need to stack that with the banks. The [email protected] ET is 350hp at the crank about 265hp to the ground. Add the throttle in a bottle to that and your looking at 350hp to the ground. You will need a set of lift pumps to keep fuel to the CP3 too.
NEXT QUESTION:
Please tell me your not doing this on a stock or near stock allison. It will take a Suncoast stage IV or V, PPE V, ATS 5, or something like that to hold that kind of power. Your looking at close to 600hp with the juice. Its pretty common knowledge that at the 600hp mark the DMAX internals are on the edge. Rods have been known to go south at 600hp.
Hope this helps
Jamie
To make a long story short, Yes the PPE has enough #2 to run the bottle.
2003 GMC LB7 DMax/Alli, 4" Exhaust w/ Muffler, 6" Rolled Edge Tip, AFE Drop-in Filter, 16x9 Moto Metal 951's, 285 BFG A/T, Debaged, Full Tint Job, Denali Grill, B&W TurnoverBall, 7" In-Dash DVD Toushscreen, Clear Headlights
Wreck' em Tech
SINGLES CLUB MEMBER #21
FOR SALE $23,500
Diamond3Max is offline
post #3 of 9 (permalink) Old 09-18-2007, 07:42 PM Thread Starter
i was told i needed the ppe ex programmer is that corrrect
post #4 of 9 (permalink) Old 09-18-2007, 09:22 PM
there are quite a few models of the PPE Xcelerater. Economy, Xcelerater, HOT, HOT+2, HOT+2 E.T.
I think The economy the lowest rated at up to 160hp (flywheel ratings) 4 levels
the regular excelerater is 220hp up to(flywheel ratings) 4 levels
The HOT and HOT+2 are the same ratings but the HOT +2 has retarded timing for nitrous and Pane. I think this is how they are rated.
check out www.pacificp.com
Jamie
Wreck' em Tech
FOR SALE $23,500
post #5 of 9 (permalink) Old 09-19-2007, 03:53 AM
diesel idiot
Personally I would ditch the drugs....you can achieve huge horspower in these trucks without them more reliably.
2004 Chevy CC/SB LB7 LT3
EFILive, SC Trans w/ 1058 by me, Traction bars and centerlink braces built by me, Custom adjustable stock wastegate, 6 inch custom exhaust, 1792 Lift Pump, Belltech 3" drop shackles, Black H2's w/ Falken 285/60/17s for summer, BFG 315/70/17s for winter, SD sleeves, DiPricol EGT and Boost gauges on the pillar along with an Aeroforce for rail PSI and trans temp, 2 Kicker Comp CVT 10's w/ memphis amp, t-rex full face billet grille,limo tint, .Oh yeah I'm 20 and I built and tuned it myself.
tahoedmax is offline
post #6 of 9 (permalink) Old 09-20-2007, 12:41 AM
GM4ever's Avatar
can you stack the edge?? i have herd good and about the Edge W attitude??
GM4ever is offline
post #7 of 9 (permalink) Old 09-20-2007, 01:36 AM
You can stack a programmer (examples: BullyDog, Predator, Quad, PPE) with an Edge box. Only trouble is trying to figure out which levels to run on them so they play nice. Some get you a LOT of timing rattle....
IIRC, the old "******* Stack" was the Quad 215 and the Hot Juice....usually netted somewheres around 500rwhp.
TheBac is offline
post #8 of 9 (permalink) Old 09-20-2007, 03:51 AM
TDG Junior Mafia #61
Dieselson's Avatar
With the PPE hot +2 you do not need or want to stack it with anything, usually too much timing, which causes timing rattle, and with nitrous may damage the engine. If you really wanted to stack, you could do like tom said, the ******* stack, but in the age of 500 RWHP EFI programs, TTS extreme, and PPE hot +2, you don't need too.
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline
post #9 of 9 (permalink) Old 09-20-2007, 04:17 AM
diesel idiot
lets be honest. stacking chips = stupid. EFI, PPE, TTS are all good. pick one.
Closed Thread
