94 E350 Won't start when hot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cattech05, this thread has received 3 replies and been viewed 4351 times.
post #1 of 4 (permalink) Old 09-04-2010, 01:51 AM Thread Starter
Anyone ever have a 7.3 idi that won't start after its been running. It will run fine and won't shut off or anything it just won't restart. Just cranks no start. Let it cool off and it starts up fine. Any ideas?
2008 F-350 C/C Long Bed 4x4
cattech05 is offline
post #2 of 4 (permalink) Old 09-04-2010, 02:04 PM
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Try pouring some lukewarm water over the injector pump. If the pump is worn this will tighten up the tolerances and it should start. You can also add engine oil to the fuel to increase the viscosity and make it easier for the sloppy IP to pump it. Obviously these are temporary fixes.
NH2112 is offline
post #3 of 4 (permalink) Old 09-04-2010, 05:50 PM
Cincinnati Guy's Avatar
Sounds like your in need of a replacement injecotr pump, d like NH2112 said and get back with us and let us know.
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
post #4 of 4 (permalink) Old 09-04-2010, 11:46 PM
A gallon of 30wt ND is cheap trouble shooting - about 1 : 20 ratio gives time to make sure it works.
Do not use cold water, if you decide to cool with water - just to the point that you can hold your hand on the pump with comfort.
Another thing on the list is the lift pump - if both are weak and the lift pump quits it could cause no start hot.
Are you using any additives? Same thing - some will vapor lock as the base stock is paint thinner or toluene. Contents are in the safety sheet - not on the label.
81 Isuzu /C223na, 5spd
keydl is offline
e350 no start problem JPscustoms 1994-2003 7.3L Power Stroke 0 05-11-2010 04:56 PM
88 E350 Ambulance 7.3 automaverick 7.3L and 6.9 IDI (Pre 1994) 0 04-29-2010 07:54 AM
85 e350 w/ 6.9L 6.0brianDRW Vehicles For Sale 1 12-10-2009 04:19 AM
2001 E350 7.3l ... triton 1994-2003 7.3L Power Stroke 10 11-30-2007 04:24 PM
98 E350 jots512 1994-2003 7.3L Power Stroke 3 03-13-2007 05:22 PM
